Steve Anderson wrote:There is something fundamentally and major wrong here. This is not just a case of a slight delay in the clamp/sync pulse.
Supplies should all be +12V, none other. Chip types should be as designated. (Quad/dual/single versions OK when you can get them).
I'll do a few more tests in the morning, including making sure I've got the timebases right.
Forget using the reversing bars file for the moment, use the JLB1 file as it's recognisable.
Read my previous posting and see if you can do the photography. I can't even make out what file you were using when you shot the previous photos.
Steve Anderson wrote:Well, that is good news! This was beginning to look like it was turning into a bad dream. But, well, it's done. Congrats!
As for the breadboarding what I have so far, it's not wasted effort, it's shown up one or two small matters that could be improved upon.
What I don't understand it why it dislikes the reversing bars waveform, I'll have a close look at that file and see if there's a reason for the the thing rejecting it.
Have you tried the monitor with real video? i.e. moving pictures, scene cuts etc..
Steve Anderson wrote:Harry, a quick check to see if low levels from the laptop are the problem, change R605 from 33k to 68k. This approximately doubles the gain but there is now a slight difference in gain between inverted and non-inverted inputs. If you also change R613 from 10k/11k to 12k the gains become x5.12 for non-inverted signals, and x5.67 for inverted inputs.
For now simply change R605, this should determine if low signal levels are the problem. But there's an increased risk of picking up noise and other crud so keep that in mind.
This may be the problem with the reversing bars signal, it's not recorded at the high-level of JLB1.
Steve Anderson wrote:OK, that's that sorted. There's a couple of things to remember here, first, the output from the laptop/CD player/whatever should be set such the video is about 1.5V p-p at 6B. Adjust the other controls to get a good picture, all being well the only control you should routinely adjust is the laptop volume control - but that's in an ideal world. You'll probably need to fiddle with others due to the care (or lack of it) in recording of the source material.
Now add a simple audio amplifier and you can watch NBTV content for as long as you have source material.
Return to The 3BP1 Anderson monitor
