Steve Anderson wrote:I noticed that in the batch of wave files I created I omitted three...here they are...
Steve Anderson wrote:The two presets are:-
VR101 allows you to set the sync-tips to 0V or a small offset if needed.
[/quote]VR102 sets the overall video amplitude.
I tend to think of SSTV as being 1kHz/V so 2.3kHz - 1.2kHz = 1.1kHz, so I chose 1.1V from sync-tips to white level as a standard here in the absence of any other. You can choose what you like, it's the FM sub-carrier that does have standards.
Harry Dalek wrote:...VR101 moves the waveform up or down on the scope to some degree like a position control ,but VR102 theres no effect on voltage or signal at all.
Harry Dalek wrote:Only thing that adjusts the amplitude is to adjust the volume control of the laptop.
Harry Dalek wrote:Mine must be working to some degree as the different frequencies do change voltage out at C1
Harry Dalek wrote:With volume on the lap top full checking 3 frequencies 1.5khz adjusting the range of VR101 testing one end to the other taking a reading at C1 AC meter reading .......
Harry Dalek wrote:I could not set VR101 on 0 volts even with no audio into the device ..
That's exactly how it should operate! So, that means IC101d is to a large extent doing its job and we can for the moment IC103, both parts are passing signals.
VR102, have you missed the 0V connection?
Measurements at 1C should be taken with a DC voltmeter
, but also feed a scope at the same time to make sure there's little/no ripple. With the test tones I uploaded in an ideal world you should simply get pure DC out, different of course for all frequencies. Forget AC measurements, what you're hoping for is no AC at all - at this stage.
Very wrong! Except at very low signal levels it shouldn't make any difference whatever the laptop puts out, that's why IC101a is there, to level-off (limit) all signals. with a signal you should get a square-wave of 20-24V p-p at the output of IC101a.
As above check with a scope, it should be DC with a slight ripple of twice the input frequency upon it. The largest ripple will be at the lowest frequencies, at 1500Hz and above it should almost be invisible.
Until these other errors are sorted out there's little point in these numbers.
At this stage it could do anything with no signal in, always have a signal present. Set VR101 only when you have a source of 1200Hz, you may be able to set it at other nearby frequencies but that's not the idea.
