Steve Anderson wrote:True, the combination of the CRT internal last anode coating and the external 'Aquadag' coating do form a capacitor. The Aquadag being at ground/0V. This can be several hundred pF on larger TV tubes and with the flyback transformer running at 15.625kHz results in a sufficiently smoothed supply, though not regulated.
They can hold a nice charge of Kv for the unwary a big glass capacitor for sure .
On a smaller CRT like this one there may be a need to add some form of additional smoothing. Again this is an area where I have little experience.
I looked back on a past try and i had no problems ,but i will look into it back then i didn't even think about a capacitor i'll see what i can do it will not hurt and i can see the benefit.
Because this appears to be half-wave rectification the diode(s) PIV rating needs to be more than 14kV if your supply is to be 7kV. If you've used microwave oven diodes in the past successfully I suggest sticking with them. I don't think having many 1kV diodes in a string is a good idea.
OK Yes microwave Diode has worked before less messy than with a string of KV diodes there might be a sparking hazard
The only thing nagging me is the speed of microwave oven diodes. These are intended to be used on 50/60Hz mains frequencies, I'm not sure how good they might be at several/dozens of kHz. I guess there's only one way to find out...
I had used it on my flyback transformers at that frequency with no problem ,its pretty rugged device
[/quote]Steve A.
Afterthought...if you had four of these diodes and the output of the HV supply is truly isolated from ground a bridge rectifier would be better. Lower PIV rating required on the diodes, half the ripple, and no DC current in the windings. Even my local supplier has some 8kV diodes in stock which are quite fast, 100ns switching time. Around US$0.30 each in small quantities. Datasheet attached.
That would be nice ~! i only have 2 i think not many ....not easy scrapped only one per microwave oven and they would all be different makes and ratings ! i don't enjoy scrapping those much as i tend to just want the diode and the tray geared motor so a lot of rubbish for the little parts the caps would more than likely hold a few KV ,have a few of those but never had a use for them and they are pretty big.
Looked at your data sheet they would come in handy i will have to look into those for the future its an interesting idea and i see your point of the bridge rectifier for this it would be spot on for what i am doing ,i will just have to make do with what i have this time around ...i will keep that idea in my mind as i like it !
