Page 1 of 1
3D Printed Bezel
PostPosted: Sun Mar 05, 2017 10:10 pm
Andrew Davie wrote:
I create the shapes in a programming language/tool called OpenSCAD. It uses what's called "constructive solid geometry". Very simple. Units are millimeters and degrees, and you just describe the shapes you want to add together, move around, or subtract from each other. You can, for example, subtract a small sphere from a larger cube and you end up with a cube with a spherical hole in it. You can shift shapes around before/after subtraction or addition. It's as simple as this...
OH i think i would find it hard Andrew not looking into this stuff for a while i played around a bit with 3d models years ago late 90s with simple 3d animation having to make my own 3d models from shapes come to think about it it was on a 486 and i could not render them to natural looking as it took to long just to render a frame .
I didn't have to think to hard about it was more adding shapes and resizing them or making shapes from points and joining the lines like a paint drawing program .
With the result...
Or, I could subtract the sphere from the cube...
Well i can see you got the hang of it 3d printers are the way to go ,i like the idea of them .
There are a number of operators in the language, and a variety of shapes. You can draw a shape and then "extrude" it to form a warped 3D version of the shape travelling through space, creating an object as it goes. Very powerful and easy to use. Here's the language cheat sheet.
i think a bit of trial and error to learn it what a great tool to make what ever shape in 3d you can think of ,i know your limited to the size of your printer but not every thing has to be big and i suppose you could make half a shape for one side then the other .
As to the materials, it's a plastic filament that looks like grass-cutter/snipper line. Usually materials called ABS or PLA. They have different characteristics (flexibility, brittleness, warping) and require different settings/skills to print.
Oh i see interesting i suppose you could make the shape for this and use it for a casting for metal object if need be ...
If you would like, I can send you something - a copy of this opto switch assembly, maybe? So you can check out how it looks in the flesh.
[/quote]
I think if possible the SSTV bezel as you mentioned would be something i didn't think of !.... looking a Klaas's monitor that would be great for the filter idea .Looking at KLass's sstv i think mine would be close to he's have to measure up/// Thanks Andrew it fine if you can't ...the bezel idea is on my mind now but ... :idea:
Re: IR sensor
PostPosted: Sun Mar 05, 2017 10:20 pm
by Andrew Davie
Harry Dalek wrote:Thanks Andrew it fine if you can't ...the bezel idea is on my mind now but ... :idea:
Let's make it happen!
Re: IR sensor
PostPosted: Mon Mar 06, 2017 5:01 pm
Well Andrew i will measure up but i am interested to know what size Klass's one is as i think picture tubes would be same size so it would be good to find out ...i am using a rather large fan housing which this screen bezel could be bolted to ..i am going to look for some clear glass i want the plastic filter behind the glass i think .
Re: IR sensor
PostPosted: Mon Mar 06, 2017 5:15 pm
by Andrew Davie
OpenSCAD can be a "parametric" language. Rather than saying the bezel is 5cm by 7 cm, we just say Xcm by Ycm, and allow X and Y to be variables that can be changed and everything reorganises around those. In other words, it's the look of the design that's important rather than the actual exact physical measurements at this stage. A rough sketch showing the features you want (a square, and inside a square viewing hole with rounded corners)... with screw holes at the 4 corners. Something like that. I'll knock up a parametric version and show you how to modify it to your exact requirements. That's how I'd do it.
Re: IR sensor
PostPosted: Mon Mar 06, 2017 9:07 pm
Andrew Davie wrote:OpenSCAD can be a "parametric" language. Rather than saying the bezel is 5cm by 7 cm, we just say Xcm by Ycm, and allow X and Y to be variables that can be changed and everything reorganises around those. In other words, it's the look of the design that's important rather than the actual exact physical measurements at this stage. A rough sketch showing the features you want (a square, and inside a square viewing hole with rounded corners)... with screw holes at the 4 corners. Something like that. I'll knock up a parametric version and show you how to modify it to your exact requirements. That's how I'd do it.
OH i see Andrew a ruff design and then it becomes serious...Well my idea would be something like Klass's with that viewing port..... behind the port i would like to glue small see through glass square and behind that the plastic yellowish filter ...depends if i can find that glass may be from a small picture frame ...but thats not needed in the viewing port build as that comes later ///Hope it isn't to hard to work out !
Re: IR sensor
PostPosted: Tue Mar 07, 2017 5:51 am
by Klaas Robers
Interesting. My son learnt me how to make Open Scad files based on parameters. And I see that I did this too for the SSTV bezel. I will try to insert a picture:
SSTV bezel
And look here: these are the parameters.
// Parameters
Dikte = 2.5;
rBuis = 53.5;
Breedte = 67;
Afronding = 8;
Gat = 4;
Gatafstand = 55;
Gatmarge = 0.1;
Ronding = 10;
rRonding = rBuis - Ronding;
Rondingafstand = rRonding / sqrt(2);
Scherm = Rondingafstand + Ronding;
Rand = 3;
Hoogte = 28.5;
Tilt = 8;
Yes, they are in Dutch, but you can read that, I can also read English, isn't it? These things are reversible, aren't they? All is in mm. Inches are out. The diameter of the visible area, corner to corner, is 105 mm in my monitor. I think Harry, yours is slightly less. But with the parameters this is easilly adjusted.
Andrew, do you want to have the text file?
Re: IR sensor
PostPosted: Tue Mar 07, 2017 7:05 pm
That looks good Klass around this size might be possible to print fingers crossed...pity on size you could print out a case for a project that would be handy !
Thickness = 2.5;rBuis = 53.5;Width = 67;Rounding = 8;Hole = 4;Hole spacing = 55;Gatmarge = 0.1;Roundness = 10;rRonding = rBuis - Rounding;Roundness = Distance rRonding / sqrt (2);Screen = Distance + Rounding Rounding;Border = 3;Height = 28.5;Tilt = 8;
Re: IR sensor
PostPosted: Wed Mar 08, 2017 7:47 am
by Klaas Robers
I see, you understand Dutch..... Well done.
Let's see what size bezel Hayy needs. It looks to be useless to print it here, at the other side of the globe.
Re: IR sensor
PostPosted: Wed Mar 08, 2017 8:02 pm
Klaas Robers wrote:I see, you understand Dutch..... Well done.
My mother inlaw was Dutch till my father inlaw wanted he's 4th wife ! :shock:
I did cheat Klass on Google translate ~! :mrgreen:
I think it could just be flat or could fit all around the Fan casing i am using ,i will wait and see what Andrew can do when he has time .
Re: IR sensor
PostPosted: Wed Mar 08, 2017 9:40 pm
by Andrew Davie
Just about anything you can think of, I can make :)
We will go through several iterations, just let me know when you are ready for a prototype and I'll put aside some time.
Re: IR sensor
PostPosted: Thu Mar 09, 2017 2:16 am
by Klaas Robers
My bezel is flat at the picture tube side. If you want to keep the fan housing, Andrew can print a wall around it. Any way the position of the screw holes should fit to your fan housing.
Re: IR sensor
PostPosted: Thu Mar 09, 2017 6:08 pm
Klaas Robers wrote:My bezel is flat at the picture tube side. If you want to keep the fan housing, Andrew can print a wall around it. Any way the position of the screw holes should fit to your fan housing.
i was thinking at first a flat face plate and just with the 4 holes to bolt it to the fan housing with the large square hole for the viewing port thats pretty simple. i should open another topic on the monitor build taking over Andrews page here .
Re: IR sensor
PostPosted: Thu Mar 09, 2017 7:08 pm
by Andrew Davie
I can move the posts into a thread specific to the bezel. I'll do that soon.
Don't create a new topic; let me do it the above way.
Re: IR sensor
PostPosted: Thu Mar 09, 2017 7:15 pm
Andrew Davie wrote:I can move the posts into a thread specific to the bezel. I'll do that soon.
OK Andrew no worries
Re: 3D Printed Bezel
PostPosted: Fri Mar 10, 2017 5:44 pm
Thanks Andrew just noticed you swapped the posts over .
I can see on your posts theres some 3D printing going on !
