Page 2 of 2
Re: SSTV NBTV ?
PostPosted: Thu Oct 25, 2018 3:07 pm
...and afterthought...
I have some FTDI USB-TTL/RS232/422/485 'cables...
https://www.ftdichip.com/Products/Cables.htm
...they unfortunately cost a bit more than one dollar!
These go up to 3Mb/s, including start/stop bits that's 300kB/s. Two bytes/sample = 150k-samples/s, a bandwidth of 75kHz. Add your own DC-coupled A-D/D-A and you're in business...for NBTV you probably want to put in an anti-aliasing filter at about 20 or so kHz.
I'm sure there's software 'out there' that will dump the data into a file and spit it out again, or some clever bod to create some. Even Hyperterminal or RealTerm should handle it.
I've just remembered, Hyperterminal doesn't like values like 0x19 that are control codes in ASCII, RealTerm has no issue as long as you specify it's a binary file, not text. I'm sure there are others, maybe TerraTerm? All three are freebies...
Re: SSTV NBTV ?
PostPosted: Fri Oct 26, 2018 6:22 am
by Monochrome
Thanks Steve,
When time permits I will have a play around with some hardware and try hacking a sound-card.
Steve wrote:
"I'm sure there's software 'out there' that will dump the data into a file and spit it out again, or some clever bod to create some. Even Hyperterminal or RealTerm should handle it."
Linux seems to be good for jobs like that though sadly my software skills are very limited. Indeed, I am currently having difficulty in simply installing Dom's nbsc software on one of my laptops :-( Thankfully, Dom has responded with some technical advice and things are looking-up a bit.
All good fun :-)
73,s
Des (M0AYF)
