Robot 70A Manual
Robot 70A Manual
Postby nomisimon » Fri Jul 15, 2022 4:45 am
Hello
I wondered if anyone had a scanned copy of the manual for the Robot 70A SSTV monitor; there isn't one on-line I can find.
I did save a copy of the diagrams posted by Steve but wondered if anyone had a full manual?
Thanks
Simon, M5POO, England
Thank God for Southby...
nomisimon
Re: Robot 70A Manual
Postby Harry Dalek » Fri Jul 15, 2022 9:03 pm
nomisimon wrote:Hello
Thanks
Little bit of information on these 2 pages link below
viewtopic.php?f=23&t=2832
Postby kd2bd » Sat Jul 16, 2022 6:27 am
Here's a Robot 70 manual. I think the 70A added a tuning indicator (sync-driven flashing LED).
73 de John, KD2BD
Robot_70_Manual.pdf
Robot Model 70 SSTV Monitor
(20.33 MiB) Downloaded 136 times
kd2bd
Mad Scientist
Postby nomisimon » Sat Jul 16, 2022 7:19 am
Thanks Harry...I've saved a copy of those. I came across them earlier when searching.
Thanks John, that's a great help. Mine is the 'A' variant, which has the 'TUNING' LED and uses 709 op-amps...but they are essentially the same otherwise I think.
By the way, we did correspond some time ago about your TriplePIC converter. I've had some health issues since 2019 which have hopefully been resolved now, but earlier this year I managed to get the PIC chips for your converter and most of the other hard to find stuff. Did you ever do a PCB layout for it or will I use good old veroboard? I saw a note on someone's post that they were looking to make a PCB...did anything come of it?
I have one of the Wrasse scan converters to play with now too.
One day I will find the model 80A SSTV camera to go with my 70A monitor.
Best wishes
Simon M5POO
nomisimon
Postby kd2bd » Sun Jul 17, 2022 2:11 am
Hi Simon.
I am glad to hear you are feeling better.
In general, the 741 is an improvement over the 709. However, the 709 has a higher slew-rate so it is a better choice for the input stage limiter. Today, there are much better op-amps to choose from.
Last year, Chris Lewis of the NBTV Association built a copy of my TriplePIC scan converter and was ambitious enough to create a PC board for the video memory / FSTV end of the converter. Details of his build are available here: https://www.taswegian.com/NBTV/forum/viewtopic.php?f=23&t=3063. During that time, I developed different firmware for the PIC16F76 to enable the scan converter to produce PAL or SECAM-compatible FSTV video.
I also started working on an improved SSTV sync detection circuit around that time, but other (life) priorities soon got in the way, so I never completed the work. Some day I will get back to it. (Sometimes it is beneficial to take a break from a project for a while, and then get back to it some time later with a fresh mind.) :)
73 de John, KD2BD
kd2bd
Mad Scientist
Return to SSTV
