A basic monitor for slow-scan television 1974
Postby Harry Dalek » Tue Jan 30, 2024 7:09 pm
I think a poorer scan has been posted in the past.
Re: A basic monitor for slow-scan television 1974
Postby BruXy » Wed Jan 31, 2024 3:47 am
Hi, cleaned a bit and joined to one 27 MB PDF:
https://bruxy.regnet.cz/hamradio/SSTV_L ... vision.pdf
BruXy
Laboratory Assistant
Postby Steve Anderson » Wed Jan 31, 2024 1:09 pm
Yes, it was I that posted the previous version. I don't know where I got that version from, but that was it, i.e. I didn't scan it. Thanks for the cleaner version.
Postby Harry Dalek » Wed Jan 31, 2024 6:12 pm
No worries just came across it reading the EA back issues .
This ones a bit different in a dual transistor valve job ,i recall our televisions were similar in this era mix .
I have not come across a electrostatic P7 i still have a another magnetic version
Postby Steve Anderson » Wed Jan 31, 2024 6:53 pm
I do have a few 'P7' type electrostatic CRTs here, a similar tube to the DP7-32 shown above is the DP7-5, though it does require somwhat higher voltages...it is an earlier tube.
I've had it for many years, one day I should fire it up...also a 3FP7, but that does require a lot of volts, 3kV as I recall. Similarly a pair of 5ADP7s...one day...
Steve A,
Return to SSTV
Users browsing this forum: Steve Anderson and 4 guests
