Source Code
Source Code
Postby Andrew Davie » Sun Mar 26, 2017 2:18 am
The source code for my Arduino Televisor is available on Github.
It's a bit of a work-in-progress learn-as-I-go experimental thing, so no doubt there are quite a few laughable bits in there.
Re: Source Code
Postby Andrew Davie » Mon Apr 17, 2017 8:43 pm
Here's a snapshot of the latest. I consolidated into a single file because it's really not that big and small files were overkill.
Code: Select all
// Arduino Mechanical Televisor        //
// This program implements all the functions needed for a working mechanical televisor using an a   //
// Arduino Micro. For more information see https://www.taswegian.com/NBTV/forum/viewforum.php?f=28  //
// program by Andrew Davie (andrew@taswegian.com), March 2017                                       //
// LIBRARIES...
// Uses the Nextion Library at https://github.com/itead/ITEADLIB_Arduino_Nextion
// backup at http://www.taswegian.com/ITEADLIB_Arduino_Nextion-master.zip
// 1: see: http://support.iteadstudio.com/support/discussions/topics/11000012238
//    --> Delete NexUpload.h and NexUpload.cpp from Nextion library folder
// 2. Disable DEBUG_SERIAL_ENABLE in NexConfig.h
// 3. set   #define nexSerial Serial1 in NexConfig.h
// Uses the SdFat Library at https://github.com/greiman/SdFat
// backup at http://www.taswegian.com/SdFat-master.zip
// HARDWARE...
// Arduino pinout/connections:  https://www.taswegian.com/NBTV/forum/viewtopic.php?f=28&t=2298
// COMPILATION SWITCHES...
// DEBUG controls the output of diagnostic strings to the serial terminal.
// SHOULD NOT BE ENABLED FOR FINAL BUILD! Don't forget to open the serial terminal if DEBUG is active,
// because in this case the program busy-waits for the terminal availability before starting.
#define DEBUG                     // diagnostics to serial terminal (WARNING: busy-waits)
#define NEXTION                   // include Nextion LCD functionality
#define SDX                       // include SD card functionality
#define SHOW_WAV_STATS            // show the WAV file header details as it is loaded
// CONFIGURATION...
#define CIRCULAR_BUFFER_SIZE 512  // must be a multiple of sample size
                                  // (i.e, (video+audio)*bytes per)) = 4 for 16-bit, and 2 for 8-bit
// Frequency modes for TIMER4
#define PWM187k 1   // 187500 Hz
#define PWM94k  2   //  93750 Hz
#define PWM47k  3   //  46875 Hz
#define PWM23k  4   //  23437 Hz
#define PWM12k  5   //  11719 Hz
#define PWM6k   6   //   5859 Hz
#define PWM3k   7   //   2930 Hz
#ifdef NEXTION
#include "NexSlider.h"
#include "NexText.h"
#include "NexButton.h"
#include "NexCheckbox.h"
uint32_t lastSeekPosition = 0;
int phase = 0;
long lastSeconds = 0;
boolean stopped = false;
NexSlider seekerSlider = NexSlider(0, 12, "seek");
NexSlider brightnessSlider = NexSlider(0, 8, "brightness");
NexSlider contrastSlider = NexSlider(0, 10, "contrast");
NexSlider volumeSlider = NexSlider(0, 11, "volume");
NexCheckbox gammaCheckbox = NexCheckbox(0, 3, "gamma");
NexButton stopButton = NexButton(0, 4, "stopButton");
NexText timePos = NexText(0, 9, "timePos");
#endif
int customBrightness = 0;
boolean customGamma = true;
long customContrast2 = 256;      // a X.Y fractional  (8 bit fractions) so 256 = 1.0f   and 512 = 2.0f
long customVolume = 256;        //ditto
volatile byte circularAudioVideoBuffer[CIRCULAR_BUFFER_SIZE];
volatile unsigned int bitsPerSample;
volatile unsigned long playbackAbsolute;
volatile unsigned int pbp = 0;
unsigned long videoSampleLength;
volatile unsigned long streamAbsolute;
volatile unsigned int bufferOffset = 0;
unsigned long sampleRate;
long singleFrame;
volatile unsigned long timeDiff = 0;
volatile unsigned long lastDetectedIR = 0;
volatile boolean IR = false;
volatile long desiredTime = 0;
boolean alreadyStreaming = false;
// PID...
#ifdef PID
#include "pidv2.h"
volatile double PID_desiredError, PID_motorDuty, PID_currentError;
PID rpmPID((double *)&PID_currentError, (double *)&PID_motorDuty, (double *)&PID_desiredError,-1,0,0,DIRECT);
#endif
#ifdef SDX
#include <SdFat.h>
File nbtv;
SdFat nbtvSD;
#endif
void play(char* filename, unsigned long seekPoint=0);
// The Arduino calls setup() once, and then loop() repeatedly
void setup() {
#ifdef DEBUG
  Serial.begin(9600);
  while (!Serial)
    SysCall::yield();
  Serial.println(F("Televisor Active!"));
#endif
#ifdef NEXTION
  nexInit();              // Initialise Nextion LCD
#endif
  setupIRComparator();
  setupMotorPWM();
  setupFastPwm(PWM187k);
  setupStreamAudioVideoFromSD();
#ifdef PID
  setupPID();
#endif
  play((char *)"who.nbtv8.wav");
void loop() {
#ifdef NEXTION
  NextionUiLoop();
#endif
// PWM to control motor speed
void setupMotorPWM() {
  #define PIN_MOTOR 3
  pinMode( PIN_MOTOR, OUTPUT );
  // If we're using an IRL540 MOSFET for driving the motor, then it's possible for the floating pin to cause
  // the motor to spin. So we make sure the pin is set LOW ASAP.
  digitalWrite( PIN_MOTOR, LOW );
  // The timer runs as a normal PWM with two outputs but we just use one for the motor
  // The prescalar is set to /1, giving a frequency of 16000000/256 = 62500 Hz
  // The motor will run off PIN 3 ("MOTOR_DUTY")
  // see pp.133 ATmega32U4 data sheet for WGM table.  %101 = fast PWM, 8-bit
  TCCR0A = 0
          | bit(COM0A1)           // COM %10 = non-inverted
          | bit(COM0B1)           // COM %10 = non-inverted
          | bit(WGM01)
          | bit(WGM00)
  TCCR0B = 0
          //| bit(WGM02)
          | bit(CS02)            // prescalar %010 = /1 = 16000000/256/1 = 62.5K
          //| bit(CS00)
  OCR0B = 255;           // start motor spinning so PID can kick in in interrupt
// PID to adjust motor speed
#ifdef PID
void setupPID() {
  PID_currentError = 0;
  PID_desiredError = 0; //singleFrame;
  PID_motorDuty = 255;                // maximum duty to kick-start motor and get IR fired up
  rpmPID.SetOutputLimits(0, 75);
  rpmPID.SetMode(AUTOMATIC);              // turn on PID
#endif
// Super dooper high speed PWM (187.5 kHz) using timer 4, used for the LED (pin 13) and audio (pin 6).
// Timer 4 uses a PLL as input so that its clock frequency can be up to 96 MHz on standard Arduino
// Leonardo/Micro. We limit imput frequency to 48 MHz to generate 187.5 kHz PWM. Can double to 375 kHz.
// ref: http://r6500.blogspot.com/2014/12/fast-pwm-on-arduino-leonardo.html
void setupFastPwm(int mode) {
  TCCR4A = 0;
  TCCR4B = mode;
  TCCR4C = 0;
  TCCR4D = 0;
  PLLFRQ=(PLLFRQ&0xCF)|0x30;      // Setup PLL, and use 96MHz / 2 = 48MHz
// PLLFRQ=(PLLFRQ&0xCF)|0x10;     // Will double all frequencies
  OCR4C = 255;                    // Target count for Timer 4 PWM
// Comparator interrupt for IR sensing
// precludes timer 1 usage
void setupIRComparator() {
  ACSR &= ~(
      bit(ACIE)         // disable interrupts on AC
    | bit(ACD)          // switch on the AC
    | bit(ACIS0)        // falling trigger
  ACSR |=
      bit(ACIS1)
    | bit(ACIE)         // re-enable interrupts on AC
  SREG |= bit(SREG_I);        // GLOBALLY enable interrupts
//-- Analog comparator interrupt service routine -------------------------------------------------
// Triggered by sync hole detected by IR sensor, connected to pin 7 (AC)
ISR(ANALOG_COMP_vect) {
  timeDiff = playbackAbsolute;
  double deltaSample = timeDiff - lastDetectedIR;
  if (deltaSample > 1000) {         // cater for potential "bounce" on IR detect by not accepting closely spaced signals
    lastDetectedIR = timeDiff;
    desiredTime += singleFrame;
    interrupts();
    IR = true;
#ifdef PID
    PID_currentError = deltaSample;
    rpmPID.Compute();
#endif
    OCR0B = 47; //(byte)(PID_motorDuty+0.5);        // write motor PWM duty
// NEXTION LCD...
#ifdef NEXTION
void NextionUiLoop(void) {
  uint32_t value;
  // Cycle through reading the controls only doing one of them each loop. Designed to reduce CPU load.
  switch (phase++) {
    case 0:
      if (gammaCheckbox.getValue(&value))
        customGamma = (value!=0);
      break;
    case 1:
      if (brightnessSlider.getValue(&value))
        customBrightness = (int)(256.*(value-128.)/128.);
      break;
    case 2:
      if (contrastSlider.getValue(&value))
        customContrast2 = value << 1;
      break;
    case 3:
      if (volumeSlider.getValue(&value))
        customVolume = value << 1;
      break;
    default:
      phase = 0;
      break;
  // Adjust the seekbar position to the current playback position
  uint32_t seekPosition = 256*(double)playbackAbsolute/(double)videoSampleLength;
  if (seekPosition != lastSeekPosition) {
    seekerSlider.setValue(seekPosition);
    lastSeekPosition = seekPosition;
  // Display elapsed time in format MM:SS
  long seconds = playbackAbsolute / singleFrame / 12.5;
  if (seconds != lastSeconds) {
    lastSeconds = seconds;
    int s = seconds % 60;
    int m = seconds / 60;
    char times[6];
    times[0] = '0'+m/10;
    times[1] = '0'+m%10;
    times[2] = ':';
    times[3] = '0'+s/10;
    times[4] = '0'+s%10;
    times[5] = 0;
    timePos.setText(times);
#endif
// Streaming from SD card
// Gamma correction using parabolic curve
// Table courtesy Klaas Robers
const uint8_t PROGMEM gamma8[] = {
    0,  0,  0,  0,  1,  1,  1,  1,  1,  1,  1,  1,  2,  2,  2,  2,
    2,  2,  2,  2,  3,  3,  3,  3,  3,  3,  4,  4,  4,  4,  5,  5,
    5,  5,  6,  6,  6,  6,  7,  7,  7,  8,  8,  8,  9,  9,  9, 10,
   10, 10, 11, 11, 12, 12, 12, 13, 13, 14, 14, 15, 15, 16, 16, 17,
   17, 18, 18, 19, 19, 20, 20, 21, 21, 22, 22, 23, 24, 24, 25, 25,
   26, 27, 27, 28, 29, 29, 30, 31, 31, 32, 33, 33, 34, 35, 36, 36,
   37, 38, 39, 39, 40, 41, 42, 42, 43, 44, 45, 46, 47, 47, 48, 49,
   50, 51, 52, 53, 54, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64,
   65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 78, 79, 80, 81,
   82, 83, 84, 85, 87, 88, 89, 90, 91, 92, 94, 95, 96, 97, 99,100,
  101,102,104,105,106,107,109,110,111,113,114,115,117,118,119,121,
  122,123,125,126,128,129,130,132,133,135,136,138,139,141,142,144,
  145,147,148,150,151,153,154,156,157,159,160,162,164,165,167,168,
  170,172,173,175,177,178,180,182,183,185,187,188,190,192,194,195,
  197,199,201,202,204,206,208,209,211,213,215,217,219,220,222,224,
  226,228,230,232,234,235,237,239,241,243,245,247,249,251,253,255
void setupStreamAudioVideoFromSD() {
#define SD_CS_PIN 4
  pinMode(SS, OUTPUT);
#ifdef SDX
  if (!nbtvSD.begin(SD_CS_PIN)) {
#ifdef DEBUG
    Serial.println(F("SD failed!"));
#endif
#endif
boolean wavInfo(char* filename) {
#ifdef SDX
  nbtv = nbtvSD.open(filename);
  if (!nbtv) {
    #if defined(DEBUG)
      Serial.print(F("Error when opening file '"));
      Serial.print(filename);
      Serial.print(F("'"));
    #endif
    return false;
  char data[4];
  nbtv.read(data,4);
  if (strncmp(data,"RIFF",4)) {
    #ifdef SHOW_WAV_STATS
      Serial.println(F("Error: WAV has no RIFF header"));
    #endif
    return false;
  long chunkSize;
  nbtv.read(&chunkSize,4);
    Serial.print(F("WAV size: "));
    Serial.println(chunkSize+8);
  #endif
  nbtv.read(data,4);
  if (strncmp(data,"WAVE",4)) {
    #ifdef DEBUG
      Serial.println(F("Error: WAVE header incorrect"));
    #endif
    return false;
  long position;
  while (true) {
    nbtv.read(data,4);        // read next chunk header
      for (int i=0; i<4; i++){
        Serial.print(data[i]);
      Serial.println();
    #endif
    if (!strncmp(data,"nbtv",4)) {
        Serial.println(F("'nbtv' chunk"));
      #endif
        Serial.print(F("size: "));
        Serial.println(chunkSize);
      #endif
      position = nbtv.position();
      nbtv.seek(position+chunkSize);
      continue;
    if (!strncmp(data,"fmt ",4)) {
        Serial.println(F("'fmt ' chunk"));
      #endif
        Serial.print(F("Size: "));
      #endif
      int audioFormat;
      nbtv.read(&audioFormat,2);
        Serial.print(F("Audio format: "));
        Serial.println(audioFormat);
      #endif
      int numChannels;
      nbtv.read(&numChannels,2);
        Serial.print(F("# chans: "));
        Serial.println(numChannels);
      #endif
      nbtv.read(&sampleRate,4);
        Serial.print(F("rate: "));
        Serial.println(sampleRate);
      #endif
      long byteRate;
      nbtv.read(&byteRate,4);
        Serial.print(F("byte rate: "));
        Serial.println(byteRate);
      #endif
      int blockAlign;
      nbtv.read(&blockAlign,2);
        Serial.print(F("align: "));
        Serial.println(blockAlign);
      #endif
      nbtv.read((void *)&bitsPerSample,2);
        Serial.print(F("bps: "));
        Serial.println(bitsPerSample);
      #endif
      // Potential "ExtraParamSize/ExtraParams" ignored because PCM
      continue;
    if (!strncmp(data,"data",4)) {
        Serial.println(F("data chunk"));
      #endif
      nbtv.read(&videoSampleLength,4);
        Serial.print(F("video size: "));
        Serial.println(videoSampleLength);
      #endif
      //position = nbtv.position();
      // and now the file pointer should be pointing at actual sound data - we can return
      break;
    #ifdef DEBUG
      Serial.print(F("unrecognised chunk in WAV: '"));
      Serial.println(F("'"));
    #endif
    return false;
  singleFrame = sampleRate * 2 * bitsPerSample / 8 / 12.5;
  return true;
#else
  return false;
#endif
void play(char* filename, unsigned long seekPoint) {
#ifdef SDX
  if (!wavInfo(filename))
      return;
  if (seekPoint) {    //TODO; not working
    long seekTo = sampleRate * bitsPerSample * 2 * seekPoint / 8 + nbtv.position();
    #ifdef DEBUG
      Serial.print("Seek to ");
      Serial.println(seekTo);
    #endif
    nbtv.seek( seekTo );
  playbackAbsolute = 0;
  streamAbsolute = 0;
  pbp = 0;
  bufferOffset = 0;
  nbtv.read( (void *)circularAudioVideoBuffer, CIRCULAR_BUFFER_SIZE );      // pre-fill the circular buffer so it's valid
  noInterrupts();
  // Start the timer(s)
  // Uses /1 divisor, but counting up to 'resolution' each time  --> frequency!
  ICR3 = (int)((16000000. / sampleRate)+0.5);         // playback frequency
  TCCR3A = _BV(WGM31) | _BV(COM3A1);
  TCCR3B = _BV(WGM33) | _BV(WGM32) | _BV(CS30);       // see pp.133 ATmega32U4 manual for table
  TIMSK3 |= (_BV(ICIE3) | _BV(TOIE3));                //WGM = 1110 --> FAST PWM with TOP in ICR :)
  interrupts();
#endif
// Buffer stuffer interrupt
// Operates at the frequency of the WAV file data (i.e, 19200Hz for NBTV8 format)
// This code tries to fill up the unused part(s) of the circular buffer that contains the streaming
// audio & video from the WAV file being played. 'bufferOffset' is the location of the next buffer
// write, and this wraps when it gets to the end of the buffer. The number of bytes to write is
// calculated from two playback pointers - 'playbackAbsolute' which is the current position in the
// audio/video stream that's ACTUALLY being shown/heard, and 'streamAbsolute' which is the position
// of the actually streamed data (less 1 actual buffer length, as it's pre-read at the start). Those
// give us a way to calculate the amount of free bytes ('bytesToStream') which need to be filled by
// reading data from the SD card. Note that 'playbackPointer' can (and will!) change while this
// routine is streaming data from the SD.  The hope is that we can read data from the SD to the buffer
// fast enough to keep the interrupt happy. If we can't - then we get glitches on the screen/audio
ISR(TIMER3_CAPT_vect) {
#ifdef SDX
  if (!alreadyStreaming) {
    alreadyStreaming = true;    // prevent THIS interrupt from interrupting itself...
    interrupts();               // but allow other interrupts (the audio/video write)
    unsigned int bytesToStream = playbackAbsolute - streamAbsolute;
    if (bytesToStream > 64) {                     // theory: more efficient to do bigger blocks
      bytesToStream = 64;                         // TODO: BUG! Remove this: no picture!! ???
      void *dest = (void *)(circularAudioVideoBuffer + bufferOffset);
      bufferOffset += bytesToStream;
      if ( bufferOffset >= CIRCULAR_BUFFER_SIZE ) {
        bytesToStream = CIRCULAR_BUFFER_SIZE - bufferOffset + bytesToStream;
        bufferOffset = 0;
      nbtv.read( dest, bytesToStream );
      streamAbsolute += bytesToStream;
#endif
// Data playback interrupt
// This is an interrupt that runs at the frequency of the WAV file data (i.e, 22050Hz, 44100Hz, ...)
// It takes data from the circular buffer 'circularAudioVideoBuffer' and sends it to the LED array
// and to the speaker. Handles 16-bit and 8-bit format sample data and adjust brightness, contrast,
// and volume on-the-fly.
ISR(TIMER3_OVF_vect) {
  long audio;
  long bright;
  if (bitsPerSample==16) {
    audio = *(int *)(circularAudioVideoBuffer+pbp+2) * customVolume;
    audio >>= 16;
    bright = *(int *)(circularAudioVideoBuffer+pbp) * customContrast2;
    bright >>= 14;
    playbackAbsolute += 4;
    pbp += 4;
  } else { // assume 8-bit, NBTV WAV file format
    audio = circularAudioVideoBuffer[pbp+1] * customVolume;
    audio >>= 8;
    bright = circularAudioVideoBuffer[pbp] * customContrast2;
    bright >>= 8;
    playbackAbsolute += 2;
    pbp += 2;
  if (pbp >= CIRCULAR_BUFFER_SIZE)
    pbp = 0;
  bright += customBrightness;
  if (bright < 0)
    bright = 0;
  else if (bright > 255)
    bright = 255;
  OCR4A = customGamma ? pgm_read_byte(&gamma8[bright]) : (byte)bright;
  DDRC |= 1<<7;                       // Set Output Mode C7
  TCCR4A = 0x82;                      // Activate channel A
  if (audio > 255)
    audio = 255;
  OCR4D = (byte) audio;               // Write the audio to pin 6 PWM duty cycle
  DDRD |= 1<<7;
  TCCR4C |= 0x09;
// EOF
Re: Source Code
Postby Andrew Davie » Sun May 07, 2017 11:57 am
Things have been really tight for some time...
Code: Select all
Sketch uses 27838 bytes (97%) of program storage space. Maximum is 28672 bytes.
Global variables use 1979 bytes (77%) of dynamic memory, leaving 581 bytes for local variables. Maximum is 2560 bytes.
Low memory available, stability problems may occur.
I'm actually using another 256 bytes of the RAM, so that's really at 87%, and I start to have upload issues (why?) when it's over 75%. I've resorted to doing "crazy things" like reducing the names of buttons on the UI to single characters, because in this screwy architecture, strings and character arrays are held in RAM, even if they're immutable. For example
Code: Select all
    if (strcmp(data,".WAV") {
The above code actually uses 5 bytes of RAM (!) because the string isn't placed in ROM (and it's zero-terminated). This means I'm replacing code like the above with odd optimisations like this...
Code: Select all
  if (data[0]!='.' || data[1]!='W' || data[2]!='A' || data[3]!='V') {
I'm also looking to avoid global variables as much as possible, but sometimes the compiler just decides "for efficiency" to make things global in scope. All a bit bizarre, really. Just for posterity, here's a snapshot of the entire program...
Code: Select all
// LIBRARIES...
// HARDWARE...
#define PID                       // enable PID code
#define LIST                      // show SD contents
#ifdef DEBUG
#endif
// CONFIGURATION...
#define CIRCULAR_BUFFER_SIZE 256 //512  // must be a multiple of sample size
#ifdef NEXTION
#include "NexVariable.h"
#include "NexDualStateButton.h"
#include "NexPicture.h"
//int phase = 0;
uint32_t shiftFrame = 65;
// Page 3 - the shift dialog
NexTouch shiftUp = NexTouch(3, 1, "u");
NexTouch shiftLeft = NexTouch(3, 2, "l");
NexTouch shiftRight = NexTouch(3, 3, "r");
NexTouch shiftDown = NexTouch(3, 4, "d");
NexTouch shiftClose = NexPicture(3, 8, "p");
NexVariable shiftValue = NexVariable(3, 5, "s");
// Page 2 - The control menu
NexSlider seekerSlider = NexSlider(2, 3, "seek");
NexSlider brightnessSlider = NexSlider(2, 1, "brightness");
NexSlider contrastSlider = NexSlider(2, 5, "contrast");
NexSlider volumeSlider = NexSlider(2, 6, "volume");
NexDSButton gamma = NexDSButton(2, 15, "gamma");
NexText timePos = NexText(2, 2, "timePos");
NexText trackName = NexText(2, 4, "t");
NexButton closeButton = NexButton(2, 16, "closeButton");
NexPicture shiftPic = NexPicture(2, 13, "p6");
// Page 1 - The file selection dialog
NexButton t0 = NexButton(1, 1, "f0");
NexButton t1 = NexButton(1, 2, "f1");
NexButton t2 = NexButton(1, 3, "f2");
NexButton t3 = NexButton(1, 4, "f3");
NexButton t4 = NexButton(1, 5, "f4");
NexButton t5 = NexButton(1, 6, "f5");
NexButton t6 = NexButton(1, 12, "f6");
NexButton t7 = NexButton(1, 13, "f7");
NexVariable baseVar = NexVariable(1,14,"basex");
NexVariable selectedItem = NexVariable(1,10,"selectedItem");
NexVariable requiredUpdate = NexVariable(1,15,"requiredUpdate");
NexSlider trackSlider = NexSlider(1,11,"h0");
NexTouch *menuList[] = {
  // Warning: overloaded usage - t0-t7 MUST BE FIRST!
  &t0, &t1, &t2, &t3, &t4, &t5, &t6, &t7, &trackSlider, NULL
#endif
int uiMode = 0;
#define MODE_INIT 0
#define MODE_SELECT_TRACK 1
#define MODE_PLAY 2
#define MODE_SHIFTER 3
long customVolume = 256;         // ditto
unsigned long videoLength;
unsigned long singleFrame;
// PID...
#ifdef PID
// PID (from http://brettbeauregard.com/blog/2011/04/improving-the-beginners-pid-introduction/)
double lastTime = 0;
double errSum = 0;
double lastErr;
double kp, ki, kd;
double motorSpeed;
byte calculatePID(double error) {
  double now = ((double)playbackAbsolute) / singleFrame;
  double timeChange = now - lastTime;
  if (timeChange > 0) {
    errSum += (error * timeChange);
    double dErr = (error - lastErr) / timeChange;
    motorSpeed = kp * error + ki * errSum + kd * dErr;
    if (motorSpeed > 255)
      motorSpeed = 255;
    if (motorSpeed < 0)
      motorSpeed = 0;
    lastErr = error;
    lastTime = now;
  return (byte)(motorSpeed+0.5);
void SetTunings(double Kp, double Ki, double Kd) {
   kp = Kp;
   ki = Ki;
   kd = Kd;
#endif
#ifdef SDX
#include <SdFat.h>
File nbtv;
SdFat nbtvSD;
#endif
boolean getFileN(int n,int s, char *name, boolean strip);
#ifdef NEXTION
// The callback "happens" when there is a change in the scroll position of the dialog.  This
// means that we need to update one or all of the 8 text lines with new contents. When the up
// or down arrows are pressed, the Nextion automatically does the scrolling up/down for the
// lines that are visible on the screen already, and we only need to update the top (0 for up)
// or the bottom (7 for down) line.  However, if the slider was used, we have to update all
// of the lines (8) - so this is somewhat slower in updating.  Not too bad though.
#define REFRESH_TOP_LINE 0
#define REFRESH_BOTTOM_LINE 7
#define REFRESH_ALL_LINES 8
void writeMenuStrings(void * = NULL) {
#ifdef DEBUG
  Serial.println(F("writeMenuStrings()"));
#endif
  char nx[64];
  // Ask the Nextion which line(s) require updating.  See the REFRESH_ equates at top of file.
  uint32_t updateReq;
  if (!requiredUpdate.getValue(&updateReq)) {
    Serial.println(F("Warning: Could not read update requirement - defaulting to ALL"));
    updateReq = REFRESH_ALL_LINES;                       // do all as a fallback
  // Get the "base" from the Nextion. This is the index, or starting file # of the first line
  // in the selection dialog. As we scroll up, this decreases to 0. As we scroll down, it
  // increases to the maximum file # (held in the slider's max value).
  uint32_t base;
  if (!baseVar.getValue(&base)) {
    Serial.println(F("Error reading base"));
    base = 0;
  Serial.print(F("Base="));
  Serial.print(base);
  Serial.print(F(" Update="));
  Serial.println(updateReq);
  // Based on 'requiredUpdate' from the Nextion we either update only the top line (when up arrow pressed),
  // only the bottom line (when down arrow pressed), or we update ALL of the lines (slider dragged). The
  // latter is kind of slow, but that doesn't really matter.  Could switch the serial speed to 115200 bps to
  // make this super-quick, but it works just fine at default 9600 bps.
  Serial.println(F("----------"));
  switch (updateReq) {
    case REFRESH_TOP_LINE:
    case REFRESH_BOTTOM_LINE: {
        if (composeMenuItem(base + updateReq, sizeof(nx), nx)) {
          Serial.println(nx);
          ((NexButton *) menuList[updateReq])->setText(nx);
      break;
    case REFRESH_ALL_LINES:
    default:
      for (int i=0; i<8; i++) {
        if (composeMenuItem(base + i, sizeof(nx), nx)) {
          Serial.println(nx);
          ((NexButton *) menuList[i])->setText(nx);
      break;
void trackSelectCallback(void *) {
  // When a menu item is selected, we read the selected item absolute number from the Nextion
  // and use that to lookup the menu string itself, and display both of them on the serial.
#ifdef DEBUG
  Serial.println(F("trackSelectCallback()"));
#endif
  uint32_t selection;
  if (selectedItem.getValue(&selection)) {
    Serial.print(F("#"));
    Serial.print(selection);
    Serial.print(F(" = "));
    char nx[64];
    boolean found = getFileN(selection,sizeof(nx),nx, false);
    if (found) {
      Serial.println(nx);
      interrupts();
      sendCommand("page 2");
      play(nx);
      uiMode = MODE_PLAY;
      OCR0B = 255;
      trackName.setText(nx);
    } else {
#ifdef DEBUG
      Serial.println(F("File not found"));
#endif
    // set track name on title in UI here
  } else {
#ifdef DEBUG
    Serial.println(F("error retrieving selection"));
#endif
void brightnessCallback(void *) {
//#ifdef DEBUG
//  Serial.println(F("brightnessCallback()"));
//#endif
  uint32_t value;
void contrastCallback(void *) {
//#ifdef DEBUG
//  Serial.println(F("contrastCallback()"));
//#endif
uint32_t value;
void volumeCallback(void *) {
//#ifdef DEBUG
//  Serial.println(F("volumeCallback()"));
//#endif
  uint32_t value;
void gammaCallback(void *) {
//#ifdef DEBUG
//  Serial.println(F("gammaCallback()"));
//#endif
  uint32_t value;
  if (gamma.getValue(&value))
void seekerCallback(void *) {
//      if (seekerSlider.getValue(&value))
// TODO: modify seek position based on seeker value
void closeButtonCallback(void *) {
#ifdef DEBUG
  Serial.println(F("closeButtonCallback()"));
#endif
  sendCommand("page 1");
//  noInterrupts();
  OCR0B = 0;        // stop motor
  uiMode = MODE_SELECT_TRACK;
void shiftStartCallback(void *) {
#ifdef DEBUG
  Serial.println(F("shiftStartCallback()"));
#endif
  sendCommand("page 3");
  uiMode = MODE_SHIFTER;
void shiftCallback(void *) {
#ifdef DEBUG
  Serial.println(F("shiftCallback()"));
#endif
  if (!shiftValue.getValue(&shiftFrame)) {
#ifdef DEBUG
    Serial.println(F("Error retrieving shift value"));
#endif
  } else {
#ifdef DEBUG
    Serial.print(F("Shift Frame = "));
    Serial.println(shiftFrame);
#endif
void shiftCloseCallback(void *) {
#ifdef DEBUG
  Serial.println(F("shiftCloseCallback()"));
#endif
  uiMode = MODE_PLAY;
#endif
void setup() {
#ifdef DEBUG
  Serial.begin(9600);
  while (!Serial)
    SysCall::yield();
#endif
#ifdef SDX
  // Setup access to the SD card
#define SD_CS_PIN 4
#ifdef DEBUG
#endif
#endif
#ifdef NEXTION
  nexInit();
  // BUG:  I have no idea why the delay below is needed, but the communication with Nextion
  // fails if it's not there - specifically, the trackSlider.setMaxValue(...) fails.  This code
  // has generic communication problems with the Nextion but seemingly ONLY ON STARTUP -
  // once the scrolling system is going, everything seems hunky dory.  So, somewhere there's
  // a mistake by yours truly...
//  delay(1000);
  while (nexSerial.available())
    nexSerial.read();
  // Attach callbacks - one for the slider, and one each for the selectable lines
  trackSlider.attachPop(writeMenuStrings, &trackSlider);
    menuList[i]->attachPop(trackSelectCallback, menuList[i]);
  // Count the number of menu items and then set the maximum range for the slider
  // We subtract 8 from the count because there are 8 lines already visible in the window
  int menuSize = countFiles();
  if (!trackSlider.setMaxval(menuSize > 8 ? menuSize - 8 : 0))
    Serial.println(F("Error setting slider maximum!"));
  writeMenuStrings();           // defaults to REFRESH_ALL_LINES, so screen is populated
  // Page 2 - controls
  seekerSlider.attachPop(seekerCallback, &seekerSlider);
  brightnessSlider.attachPop(brightnessCallback, &brightnessSlider);
  contrastSlider.attachPop(contrastCallback, &contrastSlider);
  volumeSlider.attachPop(volumeCallback, &volumeSlider);
  gamma.attachPop(gammaCallback, &gamma);
  closeButton.attachPop(closeButtonCallback, &closeButton);
  shiftPic.attachPop(shiftStartCallback, &shiftPic);
  // Page 3 - shifter
  shiftUp.attachPop(shiftCallback, &shiftUp);
  shiftLeft.attachPop(shiftCallback, &shiftLeft);
  shiftRight.attachPop(shiftCallback, &shiftRight);
  shiftDown.attachPop(shiftCallback, &shiftDown);
  shiftClose.attachPop(shiftCloseCallback, &shiftClose);
#endif
int countFiles() {
  char name[64];
//#ifdef DEBUG
//  Serial.println(F("Counting files"));
//#endif
  int count=0;
  FatFile *vwd = nbtvSD.vwd();
  vwd->rewind();
  SdFile file;
  while (file.openNext(vwd, O_READ)) {
//    memset(name,0,sizeof(name));
    file.getName(name,sizeof(name)-1);
    file.close();
    if (name[0] != 46 && strstr(name,".wav"))
        count++;
  return count;
boolean getFileN(int n,int s, char *name, boolean strip = true) {
//#ifdef DEBUG
//  Serial.print(F("getFileN("));
//  Serial.print(n);
//  Serial.println(F(")"));
//#endif
  vwd->rewind();
  SdFile file;
    file.getName(name,s-1);
    file.close();
#ifdef DEBUG
    Serial.println(name);
#endif
    if (name[0] != 46) {
      char *px = strstr(name,".wav");
      if (px) {
        if (strip)
          *px = 0;
        if (!n--)
          return true;
  return false;
char *composeMenuItem(int item,int s, char *p) {
    memset(p,0,s);
    sprintf(p,"%2d ",item+1);
    if (!getFileN(item,s-3,p+3))
      *p = 0;
    return p;
  #define PIN_MOTOR 3
  TCCR0A = 0
          | bit(WGM01)
          | bit(WGM00)
  TCCR0B = 0
          //| bit(WGM02)
          //| bit(CS00)
  OCR0B = 0;           // start motor spinning so PID can kick in in interrupt
  TCCR4A = 0;
  TCCR4B = mode;
  TCCR4C = 0;
  TCCR4D = 0;
  ACSR &= ~(
  ACSR |=
      bit(ACIS1)
int phasePid = 0;
uint32_t pbDelta;
    interrupts();
     switch (phasePid) {
        case 0:
          // Phase 0 is the beginning - if the disc is stopped, then this runs the motor at full-speed until the rotation
          // is 'nearly right' - taking into account the physical characteristics of the drive chain.  This will vary
          // from televisor to televisor. What we want to do is have the disc as close to possible to correct speed
          // AND not accellerating when we switch to the PID.
          if (deltaSample < 3072+100) {
            SetTunings(1.5,.35,1);                    // The PID that does the regular synching
            phasePid++;
            lastTime =  ((double)playbackAbsolute) / singleFrame;
          break;
        case 1:
//          Serial.println(deltaSample);
          // This next bit is super cool.  The PID synchronises the disc speed to 12.5 Hz (indirectly through the singleFrame
          // value, which is a count of #samples per rotation at 12.5 Hz).  Since the disc and the playback of the video
          // are supposed to be exactly in synch, we know that both SHOULD start a frame/rotation at exactly the same time.
          // So since we know we're at the start of a rotation (we just detected the synch hole), then we can compare
          // how 'out of phase' the video is by simply looking at the video playback sample # ('plabackAbsolute') and
          // use the sub-frame offset as an indicator of how inaccurate the framing is.  Once we know that, instead of
          // trying to change the video timing, we just change the disc speed. How do we do that?  By tricking the PID
          // into thinking the disc is running faster than it really is by telling it that the time between now and
          // the last detected rotation is actually shorter than measured. A consequence of this is that the PID will try
          // to slow the disc down a fraction, which will in turn mean the video is playing slightly faster relative
          // to the timing of the disc, and the image will shift up and left.  We also (gosh this is elegant) get the
          // ability to shift the image up/down.  So we can hardwire the exact framing vertical of the displayed image,
          // too.
          //Serial.println(shiftFrame);
          pbDelta = timeDiff % singleFrame;   // how inaccurate is framing?
          if (pbDelta > shiftFrame*2) {                           // if we need to 'vertically' adjust (OR horizontally)
              // Note, the hardwired number is televisor-specific. This is just the vertical framing counter, and can be increased
              // or decreased to shift the framing up or down.
              int adjust = (pbDelta - shiftFrame*2 ) / 8 + 1;     // use how far out of wonk as a speed control
              if (adjust > 64)                                  // but cap it because otherwise we overwhelm the PID
                adjust = 64;
              lastDetectedIR -= adjust;                         // trick the PID into thinking the disc is fast
  #ifdef PID
          OCR0B = calculatePID(deltaSample-singleFrame);    // write the new motor PID speed
  #else
          OCR0B = 53;
  #endif
          break;
        default:
          break;
#ifdef SDX
  if (!nbtv) {
#if defined(DEBUG)
#endif
    return false;
  char data[4];
  nbtv.read(data,4);
  if (data[0]!='R' || data[1]!='I' || data[2]!='F' || data[3]!='F') {
//  if (strncmp(data,"RIFF",4)) {
    #endif
    return false;
  long chunkSize;
  #endif
  nbtv.read(data,4);
  if (data[0]!='W' || data[1]!='A' || data[2]!='V' || data[3]!='E') {
//  if (strncmp(data,"WAVE",4)) {
    #ifdef DEBUG
    #endif
    return false;
  long position;
  while (true) {
      Serial.println();
    #endif
    if (data[0]=='R' && data[1]=='I' && data[2]=='F' && data[3]=='F') {
//    if (!strncmp(data,"nbtv",4)) {
      #endif
      #endif
      continue;
    if (data[0]=='f' && data[1]=='m' && data[2]=='t' && data[3]==' ') {
//    if (!strncmp(data,"fmt ",4)) {
      #endif
      #endif
      int audioFormat;
      #endif
      int numChannels;
      #endif
      #endif
      long byteRate;
      #endif
      int blockAlign;
      #endif
      #endif
      continue;
    if (data[0]=='d' && data[1]=='a' && data[2]=='t' && data[3]=='a') {
//    if (!strncmp(data,"data",4)) {
      #endif
      nbtv.read(&videoLength,4);
        Serial.println(videoLength);
      #endif
      break;
    #ifdef DEBUG
    #endif
    return false;
  return true;
#else
  return false;
#endif
#ifdef SDX
      return;
    long seekTo = singleFrame * seekPoint * 12.5 + nbtv.position();
#ifdef DEBUG
      Serial.print(F("Seek to "));
#endif
  streamAbsolute = 0;
  pbp = 0;
  bufferOffset = 0;
  noInterrupts();
  interrupts();
#endif
#ifdef SDX
        bufferOffset = 0;
#endif
  long audio;
  long bright;
    audio >>= 16;
    bright >>= 14;
    pbp += 4;
    audio >>= 8;
    bright >>= 8;
    pbp += 2;
    pbp = 0;
  if (bright < 0)
    bright = 0;
    bright = 255;
  if (audio > 255)
    audio = 255;
  DDRD |= 1<<7;
  TCCR4C |= 0x09;
void loop() {
  switch (uiMode) {
    case MODE_INIT:
      setupMotorPWM();
#ifdef PID
      SetTunings(1.5,0,0);
#endif
      break;
    case MODE_SELECT_TRACK:           // file selection from menu
#ifdef NEXTION
      nexLoop(menuList);
#endif
      break;
    case MODE_PLAY:           // movie is playing
#ifdef NEXTION
        NexTouch *controlListen[] = {
          &seekerSlider, &brightnessSlider, &contrastSlider, &volumeSlider, &gamma, &closeButton, &shiftPic, NULL
        nexLoop(controlListen);
        uint32_t seekPosition = (playbackAbsolute << 8) / videoLength;      //256*(double)playbackAbsolute/(double)videoLength;
          char times[6];
          if (m/10)
          else
            times[0] = ' ';
          times[2] = ':';
          times[5] = 0;
#endif
      break;
    case MODE_SHIFTER:           // movie is playing and we're looking at the frame-shift dialog
#ifdef NEXTION
        NexTouch *shiftListen[] = {
          &shiftUp, &shiftLeft, &shiftRight, &shiftDown, &shiftClose, NULL
        nexLoop(shiftListen);
#endif
      break;
    default:
      break;
// EOF
Re: Source Code
Postby Andrew Davie » Sat Jun 17, 2017 12:28 am
I've just updated the GitHub repository with the Arduino code, the Nextion library source code (I made some mods to the library and want to keep!), the Nextion binary and design files, the LED matrix Eagle files (board, schematic). Also added a sample NBTV8 format file for playback. So that should be a complete version saved for posterity.
Re: Source Code
Postby Andrew Davie » Sat Jun 17, 2017 12:23 pm
Andrew Davie wrote:
Code: Select all
Even that can be optimised, and replaced with something similar to this...
Code: Select all
if (data != 0x45564157) { //'EVAW'
This treats data as a 4-byte integer and compares with the number represented by the letters in little-endian format. So, left to right, E..V..A..W represented in hex format in the above bit of code. To use in the initial example, replace the letters ".WAV" with the equivalent hex. It compiles down to a much smaller footprint, and of course is quicker to run, too, being just a single comparison.
Re: Source Code
Postby Andrew Davie » Sun Jun 18, 2017 2:44 am
I spent a few hours removing the conditional compilation for NEXTION and DEBUG from the source code. Essentially, whereas previously you had to tell the code if a Nextion LCD was present or not, and also if it should output debug messages or not - now these are automatically detected. The Nextion initialisation code determines if there's a Nextion that's talking to the Arduino and if NOT, then the code will automatically play all the video files on the SD card (i.e., no UI). If the Nextion is detected, then the normal UI file selection is presented. As to debug mode, on startup the code looks for the presence of any data on the serial port - it does this for a few seconds. If it finds anything, that means that there's someone on the other end, and so it enables debug output. This means that debugging info will be available in the final version just by plugging in to the Arduino's USB port and sending a character to it just after you turn on your televisor. It also means you don't have to re-upload the code to the Arduino for different configurations (with/without debugging and Nextion).
