Re: The Tasmanian Devil VCR139....A for Andrew
Posted: Wed May 31, 2017 2:43 pm
Progress indeed Harry...I'll leave you get on with it...
178k is near enough, even 170-190k should be fine. Don't forget that multimeters on the resistance ranges are less accurate than on voltage, plus it may need calibrating - but few do that. A 1% resistor is more than likely to be more accurate than the meter.
Just because things may be 'digital' it doesn't mean they're accurate. e.g. A DS18B20 direct-to-digital thermometer has a resolution of 1/16 of a degree Celcius. If it's saying the temperature is 20.0000 degrees and it gets slightly warmer it outputs 20.0625 degrees. But the accuracy is +/-0.5 degrees. It actually could be anywhere, say 20.4375 degrees.
So when matching components, it's usually not the precise value that's important, but they read as close as required.
