Motor Unit Construction
A build to model parts for a Baird lens box, the type seen on televisors, suitable for 3D printing and use on a televisor model.
Postby McGee2021 » Wed Jul 05, 2017 9:18 am
I have finally decided to 3d print the framing mechanism, and i have sent away files to laser cut sheet metal to make the 30 tooth wheel. But in order to do this successfully, ill need to use a double shaft, universal motor. I have looked and looked, but there seems to be an extreme shortage of them. I was hoping to find one similar to the one Denis Asseman used in his televisor replicas, but i have no information on it other than it was french made. Does anybody know where to source this motor? The Motor he used can be seen here: http://users.skynet.be/telehor/nieuwe_pagina_7.htm
Fun times, ain't it?
McGee2021
Re: Motor Unit Construction
Postby McGee2021 » Wed Jul 05, 2017 10:00 am
The 150 ohm variable resistor came in the mail today and was about 1.5 times the size of what the seller stated! I have glued together the ceramic resistors, them being one 400 ohm, and five 60 ohm resistors.
(93.4 KiB) Not downloaded yet
McGee2021
Postby McGee2021 » Thu Jul 06, 2017 6:49 am
(380.68 KiB) Not downloaded yet
I have finished 3d printing the resistance unit, and have printed off a bracket to hold the variable resistance. I am heading out tomorrow to get a piece of wood suitable for the base, and hope to have a base done by Friday.
McGee2021
Postby McGee2021 » Thu Dec 07, 2017 4:30 am
I had the chance last night to get caught up on my part making, and managed to make the motor stand and 20 inch disc hub.
McGee2021
Postby McGee2021 » Mon Jan 22, 2018 5:47 am
I've had a "secondary winter break" this week from school due to snow days, and I used most of my time to design some final renditions of parts, and I have completed the motor unit, minus the sync gear and magnets, which I have sent off the metal for machining. Last nite, I was up till two A.M. designing the brackets to hold the motor to the stand, and I have mounted the motor unit.
McGee2021
Postby McGee2021 » Mon Jun 10, 2019 6:35 am
I've been off the forum for almost a year now due to an extreme bout of depression, and have finally managed to force myself to continue work on the things i take interest in just short of 2 weeks before me 16th. The only part of this project that i have yet to do is to complete the framing mechanism and to mill off the toothed sync gear, and since Ive recently gone into a position at a local student run engineering firm, ive gained a great advantage to complete this project since we run CNC mills almost daily. Updates to come soon hopefully.
McGee2021
Postby Harry Dalek » Mon Jun 17, 2019 9:30 pm
Good luck it's looking good look forward to seeing it all going .
Wish I had your skills your a much better constructor than me ....and at 16 I was more hopeless I think I could just make electromagnets then.
Return to Baird Lens Box and Face plate
