smeezekitty wrote:Not a valve, its a discharge tube...It has no label.
Right, identified it from the parts list and the circuit diagram, it's an OG3 (V609). It's part of the -100V power supply. I have only seen this arrangement once before in a Harris 250kW TV transmitter, I would have expected to see something like a VR150. But I guess they had their reasons.
I haven't been able to find any data on this tube but analyzing the circuit I suspect the flashing is normal. One way to confirm this is to measure the -100V supply on pin 23 of both plug-in units. After all this time it might not be
exactly -100V, but within 5% should be fine.
Interesting to note that the Philips datasheet for the two wire-ended 5642 EHT rectifiers (V822 & 832) rates their life at only 500 hours! They probably lasted far longer than this but for a professional piece of equipment left on eight hours a day that's less than three months! One of the reasons I suspect they changed to semiconductors for the 561B.
The reason for the dim display could be these two tubes are past it, and probably the arcing you had didn't help. I would very tempted to find a source for these and the 6CZ5 (V800). In the US I have found these two...they both have both tubes...
Antique Electronic Supply, (AZ),
www.tubesandmore.com
Vacuum Tubes Inc. (FL),
www.vacuumtubesinc.com
The 12BH7 (V814) used as part of this EHT inverter you should be able to get almost anywhere.
