smeezekitty wrote:No, i resoldered the wires.
Ah, the beauty of ambiguity. Steve probably meant "Have you put the plugins back into their original positions" or something similar. Not "Have you got new ones".
smeezekitty wrote:New problem! High voltage arcking noise from CRT tranformer box.
smeezekitty wrote:Ignoring the 5kv i opened the high voltage box to find and aluminum bar stuck in there. I removed it but the CRT only works when you hold down sweep reset and the knobs are set in certain ways.
----edit----
The 5kv short may have fried a valve because V800 had a blue blinking glow
Steve Anderson wrote:OK, seems we're getting somewhere...
1) Have you re-inserted the vertical amplifier (left-hand plug in) or not? If not, don't fit it yet. If you have leave it in.
Position-centred.
Time/Div (big outside 22-position switch) at-2mSEC-
Variable-(smaller red knob concentric with above)-fully clockwise where it will click at the end-stop (a switch) The 'Uncal' Neon on the front of the plug-in should go out.
Mode-Normal (up)
Slope +
Coupling-AC Slow
Source-Int.
That should give you a horizontal straight line right (or almost) across the CRT face. Adjust the 'Focus' and 'Intensity' controls for best looking line (top right main chassis front)
This timebase model doesn't use the 117V that is fed to it. Pins 7+8 on the rear connector of the plug-in shouldn't be connected internally.
Let me know the model no. of the left-hand plug-in. When this is fitted (if you haven't already) this might give a brighter trace with better focus.
Even though very dim do the front panel focus and intensity controls do anything?
smeezekitty wrote:There is a discharge tube under the high voltage that is blinking twice a second.
Users browsing this forum: No registered users and 36 guests
