DrZarkov wrote:The idea is great, I thought before to buy some wood or plastic bars, form a mirror screw in the same way you suggested, and just glue some metallic tape (like this one: http://www.fancy-tapes.co.uk/store/product/63-0/ ) on it. I found somewhere smaller self adhesive tapes only 1 cm wide. With 32 lines this would make a nice, big picture. Of course 3/4" would make an even bigger picture, but you will need a very strong motor...
(BTW: Why did you start this thread in "off topic"?)
Klaas Robers wrote:Harry, the strips must be flat and polished like a mirror. That is the reason they are first clamped together dorming a flat plate, then that plate is flattened and polished to a mirror. If it is really a flat mirror, then the clamping rod is released and the plates are rotated one by one to form the mirror screw.
If the plates are not really flat you will get ragged lines and an awfull picture. The scanning light spot is the image of the line light source that you see in only one of the mirrors at the time. So they must be perfect mirrors otherwise you see a vague spot, making vague pictures, if you recognise them at all.
This is the part that makes the MIRROR-screw a difficult to make thing.
DrZarkov wrote:I like the old idea of TeKaDe to form a mirror-screw of Bakelite, and chrome plate it. Well, of course today we would not use Bakelite, but we would render a mirrorscrew with a software like Blender, and print it with a fabber (which became available for private customers in a decent quality for less than 2000 EUR). The leaves the problem how to chrome plate it in a sufficient manner.
harry dalek wrote:Gary has made a machine that made he's lens disk wonder if it could do a screw ?
gary wrote:harry dalek wrote:Gary has made a machine that made he's lens disk wonder if it could do a screw ?
well, yes and no - I think DrZarkov was considering making a 3D mirror screw (or at least the shape) that would be like it had been cast in a mould - my machine is only what they call 2.5D, that is, while it has x y and z axis it can't undercut etc and therefore can't make true 3D objects - however it could make all the flat parts no problem, at least in aluminium, I don't think it is sturdy enough for stainless.
BTW have you seen the 3/16" plywood mirror screw that Peter Yanczer made? (see newsletter #16 V1). He glued a strip of glass mirror to the edge - it's a bit of a mystery how he cut the glass strips though, I was thinking it oughtn't to be that hard to use plastic mirror stock.
In any case, except for the fact that the paddle pop sticks are pre-cut in the length dimension are they really any advantage over using aluminium strips?
Looking at your pictures I guess at the very least they give you some experience in the assembly process at a very low cost.
gary wrote:Oh well any $2 shop will have plastic mirrors but I suppose for a mirror screw you might need front surface (and maybe it's not that important anyway) - if so you can get it through the club shop.
Bunnings have the strip here (Sydney), but I found Mitre 10 were a little cheaper - don't forget that the thickness determines the size of the picture and so the thicker the better really unless you are trying to make a mini version - I would say the 2mm strip is just about right for a small screw (2 1/2")
Users browsing this forum: No registered users and 52 guests
