Page 1 of 1
O-Silly-Scope
PostPosted: Mon Apr 18, 2011 12:02 pm
by gary
I came across an item on YouTube which I found interesting called OscilloFun.
We NBTV-ers are familiar with using oscilloscopes to display NBTV using the X, Y, and Z (or pwm) channels, but it delights me to see that you can create graphics such as 3D boxes and text with what, to the ear, appears to be passable music.
Someone posted a link to a FLAC version of the music (oscillofun.flac). I have converted it to wav and, for those who don't own an oscilloscope and wish to try it, have written a small virtual 'scope to display it on. I also attach a link to a video showing it running on my PC (BTW it will require a modernish PC running windows >= XP).
http://www.youtube.com/watch?v=-zYBRFvO1gQ
PostPosted: Tue Apr 19, 2011 1:49 am
by Lowtone
Nice :P
Do you know if a programm allows to "write" on spectrograph ?
PostPosted: Tue Apr 19, 2011 4:04 am
by Dave Moll
See also YouScope. I'm sure I have a WAV file of (an earlier version of) this (feeds into X and Y inputs of 'scope) somewhere, but can't lay my hands on it at present.
Playing it from my (now deceased) laptop, I remember that the inversion problem meant that I had my 'scope lying on its back to watch it!
PostPosted: Tue Apr 19, 2011 5:12 am
by Lowtone
PostPosted: Tue Apr 19, 2011 11:49 am
by gary
Lowtone wrote:Nice :P
Yes I have written a (slow) version of such a programme and could post it if you like, but there are lots of (better) free versions on the net (e.g. google bitmap&wave etc).
Audacity is a good free way of viewing this type of file.
PostPosted: Tue Apr 19, 2011 12:30 pm
by gary
Dave Moll wrote:See also YouScope. I'm sure I have a WAV file of (an earlier version of) this (feeds into X and Y inputs of 'scope) somewhere, but can't lay my hands on it at present.
Yes I have that (see attached).
I guess the main difference between this and the spectrum files to the oscillofun files is the latter is truly "listenable" in it's own right - someone went to a great deal of trouble to achieve that.
Edit: It seems uploads are disabled or there is a server problem at the moment - I will try to upload later.
Edit: looks like the full item was too big to upload - here is part 1 - let me know if anyone wants part 2
PostPosted: Tue Apr 19, 2011 5:12 pm
Dear All,
There is a 20MB limit on uploads...probably the default value in the forum software. But that can be changed if you wish to upload a larger file...just let Andrew, Dave or I know and we'll give you the green light.
PostPosted: Thu Apr 21, 2011 4:41 am
by Lowtone
It would be nice to try :D
gary wrote:Audacity is a good free way of viewing this type of file.
I use Gram 5 to see spectrographs
PostPosted: Fri Apr 22, 2011 2:48 pm
by gary
Lowtone wrote:It would be nice to try :D
Here it is then - warning don't bother trying it on very large images unless you have a lot of time or processing power available:
Here is an example of a familiar image:
and as displayed in cooledit 2000
(note the generator is optimised for a band resolution of 256)
PostPosted: Sat Apr 23, 2011 4:12 am
by Lowtone
Ah thanks :P
It works but really good with Gram 5, I have to speed up the file in order to display the picture
PostPosted: Sat May 07, 2011 3:53 am
by Alan
I have deliberately posted this to "O Silly Scope" because that is what I am begining to believe I have bought.
Yes, it is a (ARM) DSO 201 nano hand-held scope from eBay.
It came without any destructions, and what I have managed to glean from the net is most confusing. (It is not written in a format that in my dotage, am I able to understand).
I have bought a microSD card, formatted it in FAT16 ( a format foreign to LINUX), but cannot get it to save, let alone display, traces, tho' it gives a lovely clear trace from the Triple Waveform Generator.
Anyone got any exoerience with this toy?
Many thanks,
Alan
O Sil Oscope
PostPosted: Sat Jun 11, 2011 8:12 pm
by Alan
DSO201 - Problem solved!
Eventually sent to Seeed Studio forum at www.seeedstudio.com/forum/viewforum.php?f=12 (Yes, 3 * 'e' in the name)
There it was suggested that SD card was faulty or not properly in contact. The latter proved the fault - judicious use of a fingernail finally pressed the card home. Then up came functions that were previously missing. A fine little gadget!
Alan.
