gary wrote:Hi Harry, I am not sure but you seem to be thinking that all encoders exhibit this phenomenon - but I assure you MY encoders don't behave the same way YOUR encoders do.
Hi Gary well this is a good thing 2 ways of doing the same thing is a good and interesting .
It is something to do with with the difference between using ink (as in your case) and toner (as in my case) - even though to the eye they appear more-or-less the same.
Another case of the IR light either reflecting off some thing or absorbed ,i still don't understand if the light on the black in yours is absorbed due to the white in mine seems to do that and theres no ink on that or is there in the bleaching of the paper to white mmmm again Yakes
Heat and IR are NOT the same, it is just that HOT bodies tend to give off radiation strongly in the IR part of the spectrum (they give off visible light too and all other parts of the spectrum dependent on their temperature. The hotter the object the higher the frequency of radiation - thus it goes from IR to red to yellow, to blue and so on).
But we would be dealing with very low end IR of the spectrum so are we dealing with the invisible heat only low end red we can not see ...i am getting my head around if this frequency of light is absorbed more than reflected by black you would think white would reflect all light the same or be the best reflector apart from a shiny surface but its not the case i can see.
I can understand if some thing of a dark colour absorbs the ir light and looks hotter as in the test papers i did today purple and black were the best.
A TRUE black body is opaque and totally non reflective to ALL of the electromagnetic spectrum.
If it doesn't reflect the light pointed at it the light would be absorbed and turned into heat and reflect that so i am thinking it does as the light would have to be turned into some thing as the photons don't vanish ?
It is totally possible for something to appear black to our eyes and yet emit radiation in all of the rest of the electromagnetic spectrum including IR. This would be what we refer to as a notch filter. You are familiar with a notch filter? We use a notch filter to say, filter out 50 Hz mains hum from audio or video.
Now your printers black ink may well have a response of a notch filter (or a low pass filter) but the analogy would be that my 50Hz audio notch filter filters out 49.999 Hz - something that is not only unheard of, but is physically impossible to implement. That is why I find this phenomenon extraordinary.
I have heard of a notch filter yes low pass filter ; ) sounds like we have a pretty good filter effect.
I can see whats happening my end with the ink on the white paper i am using i don't know what really should happen as with most and your encoders what the same experiment does on these .
I fully concede that my logic is purely restricted to the "ideal" world and that there are other factors associated from a far from ideal implementation - but you would expect this to result in a variation in DEGREE only - yet the fact that there is virtually no difference in reflectivity (read magnitude or luminosity) between a visually "white" segment and a visually "black" segment to IR is, well, astonishing.
I would of expected a difference but looks like all inks are not the same don't you think the luminosity of the led and the sensitivity of the photo trany is a factor we have not looked into perhaps adjusted might get them in range to see as per normal but i do like the idea of a different encoder method .
The MOST astonishing thing is, as it appears to me, is not only does there appear to be the equivalent of a "brickwall" filter response, but that it is "naturally" occurring - totally by chance???
The laws of this universe seem to make it possible ,i do find it very interesting that 2 opposites gives the same result.
Now, if we had a full spectrum response over the bandwidth concerned *maybe* it's not as astonishing as I think - maybe a large part of the RED spectrum is unattenuated too so it's not such a brickwall filter as I think - if someone knows or thinks so please let me know.
Well not me it makes my brain hurt all i wanted to do is make a reflecting light switch.
BTW Harry - I may be wrong, but I sense a degree of scepticism in your belief that these "printed" encoders work at all, regardless of how they are printed. If I am correct I would draw your attention to the numerous MUTR Televisors out there that are using that self same encoder quite nicely.
Well at first till i made it work my way .....what i am interested in is i would like to see the reflective test via say a mutr encoder like i did on mine ...how well it reflects and absorbs light on the black ink and white paper there must be a difference if any one out there in NBTV land has a remote an encoder and a digital camera most IR sensitive i for one would love to see the results .
PS: I had considered the difference in "thickness" of the layer of ink and a layer of toner as a possible reason. However it doesn't *seem* to have a significant effect on the visible light part of the spectrum. I guess there remains the possibility that the thickness and shorter wavelength have some correspondence - but that in itself would be remarkable.
