gary wrote:I PROMISE this will be my last post on the subject of the Falkirk transmitter serrated disk, this is an excerpt from "Television, an international history of the formative years" by one of our past NBTVA presidents R. W. Burns.
harry dalek wrote:One thing on the last few posts on Bairds second disk how did he keep the thing from drifting i expect drifting i can only think he used battery power still once that drops it would still be as bad as a poor Ac supply ours now gos up and down by a few volts .
Or did it matter ? i expect drifting but i am not sure if it will effect the video much if its kept with in a correct range ...
gary wrote:That's a pretty good question Harry, Baird would have had access to synchronous motors, probably more so than we do today, yet I doubt he did that for the serrated disk.
Doing a lot of manual motor control you tend to get use to adjusting readjusting things just a touch i was thinking he might of been doing that but its one experiment i have not tried and i am not sure if it would effect in the same way in as in hes mechanical chopper, but adjust the PWM clock frequency so change the band width in that type of display circuit.For the purpose of his exercise I doubt he worried too much about the speed unless it adversely effected his "first differential" (i.e. the magnetic response of the transformer) - If he demodulated his signal with a synchronous chopper demodulator then he would just have used the other side of the serrated disk (presumably).
I have not seen any thing on the other side of that disk so perhaps the first answer ...(I know the previous was supposed to be my last post on the Falkirk tx but this is really an answer to a mag amp question.)
Well its the same sort of thing light choppers and it is my thread so you can answer much as you like on both versions.In your case Harry I fear that you will be so beset with phase errors and magnetic non-linearities I doubt that it will matter too much in your case either - but if you are concerned about it as regards my challenge then if it works with a xtal locked oscillator but not with a serrated disk (due to speed issues) I would concede and crown you winner .
I am interested to see the frequency and waveform...i think it will be a bit like controlling a manual nbtv picture ,i didn't think of it before on the waveform but this with a photo trany is a sine wave wonder if its the same on the LDR
Trying to keep it simple with all the issues of simple my other idea of an early clock type would be the carbon arc oscillator not some thing i want to try in the houseIn addition, and to make things easier, I would also allow the source of the video signal to be a non-mechanical source (cd player pc etc) PROVIDED that the signal is demonstrably amplified by the order required in pre-valve days and plays reasonably well on, say TBP?
If i get as far as doing the amp i wanted to try a test we did like the head amp led test a nbtv wave file being transmitted via a LED via the pc sound card ....being received by another LDR or solar cell then via the magnetic amp and out put recorded so we can sort of can tell with out the mechanical disks for camera monitor if the electrics in this case work in best case ..A committee needs to be assembled to ascertain what the order of amplification should be
gary wrote:Clever ad that Harry
BTW with your encoders I presume you will NOT be using an IR sensor? otherwise how are you getting around your laser printer problem? That's a LOT of cutting out if you use your normal method.
BTW my investigation of that problem has caused quite a stir on the HP printer forum as every one agrees it is just a ploy by HP to waste colour ink - they certainly haven't denied it.
gary wrote:Oh BTW Harry I forgot to mention that you could conceivably design an encoder disk with segments so shaped as to produce a sine wave which would reduce your harmonics considerably - perhaps best left until you get something working.
Users browsing this forum: No registered users and 66 guests
