gary wrote:Harry it's a real pity that you didn't have an encoder version when the disk was steady - also how did you stop the slow roll? using the 22pf trimmer?
It would be good if you switched between crystal and encoder syncs half way like you did before.
It seems that the sync bar is halfway whether it's crystal or encoder so I would think that means it a detector/encoder alignment issue.
Harry Dalek wrote:I have been thinking about this and i thought i put the reflective white to the start of the line again if thats correct but i wonder if theres over lap the encoder is to large and other lines are being over lapped ...as i said curse of the encoder it will never end till i make every mistake
gary wrote:
Is there any chance of a photo showing the detector and encoder front on (or rear on depending on how you have it)? Or is that impossible without pulling things apart?
I will see what i can do on the photos
Klaas Robers wrote:Harry, I see that you have a missing sync pulse on your encoder disc. You use this output for the speedcontrol of the disc, however you compare it against an output signal of the 4060, which has NO missing pulse. That will not match and introduces at least speed variations on your disc.
So, unless you manage to make a missing pulse,every 12.5 sec, in the 400 Hz signal out of the 4060 (this is very difficult) the encoder should give uninterrupted sync pulses. For the missing sync pulse you could make an extra ring on the encoder disc, with only one pulse. In an electronic way this one sync pulse per revolution may suppress one sync pulse from the 32 on the outer ring.
[/quote][/quoteoS, unless you manage to make a missing pulse,every 12.5 sec, in the 400 Hz signal out of the 4060 (this is very difficult) the encoder should give uninterrupted sync pulses. For the missing sync pulse you could make an extra ring on the encoder disc, with only one pulse. In an electronic way this one sync pulse per revolution may suppress one sync pulse from the 32 on the outer ring.
gary wrote:Hi Harry, how far is the tip of the detector from the encoder?
Harry Dalek wrote:gary wrote:Hi Harry, how far is the tip of the detector from the encoder?
i would say about 5mm i tried pulling it away while looking on the scope and i lost signal this was giving best result on the scope i had to angle it a touch as well.....the the sine wave signal looks pretty neat from the opto reflector HOA1405....i checked the data sheet seems thats about right as well./
gary wrote:
Ok, from memory that is the optimum distance.
I am having trouble coming up for a "physical" explanation for the waviness of the sync bar when taken from the encoder. I thought it was an artefact of the "hunting" you were having but in these tests the hunting changes from none or nearly none to fairly severe but the amplitude of the waviness appears to remain the same.
Harry, this is a long shot, could you check, with a ruler, that the encoder is circular rather than elliptical - the picture a few posts back seems to indicate it is quite elliptical but that could be just the angle of the camera - but some printers have been known to print anisotropically. However, it's hard to imagine even that would result in the variation we are seeing.
The wav files do indicate that you have a substantial 'glitch' where you added the extra segment, which probably doesn't help in speed stability either.
[/quote][/quote]I found this that I think I used on one of my cameras:
