Just uploaded recently. It shows an interesting example of NBTV compressed to work within the bandwidth of a normal 45 RPM record. He also touches on early recordings by Baird and mechanical TV
https://www.youtube.com/watch?v=UtNGVb94TFE
DrZarkov wrote:Impressive. I own an old "TED Bildplattenspieler" from Telefunken, made in 1975. It uses also vinyl records, has crude colour pictures, but a reasonable sound quality. One records plays for 10 minutes. The disc spins with 1,500 RPM, for the picture it uses a special extra fine diamond, which will be polished before every use. The grooves are 40 times smaller than on a normal record. If you would combine that old technology with VinylVideo, full HD 90 minutes recordings on a 30 cm disc should be possible. But it wouldn't be cheap...
Users browsing this forum: No registered users and 12 guests
