Apollo TV and MSTV.
Apollo TV and MSTV.
Postby Steve Anderson » Wed Sep 01, 2021 9:01 pm
The early Apollo moon-missions used a unique and custom TV system, at first in monochrome, later in colour. It was a mish-mash of a system using either 320-lines at a 10Hz frame rate, or a Hi-Def mode of 1280-lines (very familiar now) at 0.625Hz, i.e. 1.6sec/frame. I don't think the HD mode was ever used on actual missions though. In either mode the video needed to be kept within a 500kHz bandwidth, that's all the Moon-Earth link had available for video.
In my mind it's not quite 'TV', nor SSTV, more like a higher resolution version of NBTV, the frame rate isn't that dissimilar. In the absence of any thing else - MDTV (Medium Definition TeleVision), though that could encompass many others.
The fundamental baseband video parameters are below, 'Click' as usual. It used a 'Sync Burst' rather than a pulse, other than the modification of line/frame frequencies , amplitudes and a few other details, it should be quite familiar. This data is only for the monochrome system, aside from the colour system, (same as early US CBS colour), using a RGB motor-driven sequential arrangement I have very little info.
We all remember (though perhaps I should say 'some' now) the quality of the results, not exactly stellar! One day I'll have a go at reproducing 320/10 for no other reason than why not? Maybe then we can see what could have been. Though that's easy to do in no time at all - convert a JPG to monochrome, resize to 428x320 (3:2 aspect ratio) and that's what could have been (without the 500kHz filtering). But that's not fair on those lumbered with the time/cost/reliability/operational constraints.
Also conversion from 320 to 525 had to be done on Earth, then in most of the world 525 to 625, or 405 which is how I saw it live on TV. I was 13 at the time...
ApolloTV-Acrobat5.pdf
(11.46 MiB) Downloaded 237 times
LC-SOW.pdf
(3.45 MiB) Downloaded 255 times
Re: Apollo TV and MSTV.
Postby Lowtone » Fri Sep 10, 2021 5:32 am
converted to 819 too at that time.
Here is an interesting clip of camera failure on the moon
[youtube]https://www.youtube.com/watch?v=UtBMAMO11e8&ab_channel=MoonInGoogleEarth[/youtube]
Also this website that shows eveything, picture of the 320 line monitor, super 8 footage of it, schematics of the transmission system.
https://honeysucklecreek.net/Apollo_11/tapes/
https://honeysucklecreek.net/Apollo_11/index.html
https://honeysucklecreek.net/Apollo_11_EVA_stills/images/A11TV05.jpg
r a d i o P T T v i s i o n
Lowtone
Postby Steve Anderson » Fri Sep 10, 2021 11:53 am
Lowtone wrote:...and converted to 819 too at that time.
Oops, I forgot about 819, sorry...
Here's two links which are related to the Lunar Orbit craft that took hi-res photos of proposed Apollo moon landing sites and the discovery and restoration of the tapes. Unlike Apollo 11, these tapes were found...
http://www.thelivingmoon.com/47john_lea ... Found.html
https://moonviews.com/
Some of the embedded links within the sites may or may not work...they've been up for years with little or no maintenance...
Postby Lowtone » Sat Oct 01, 2022 8:17 am
Lowtone
Postby Harry Dalek » Sat Oct 01, 2022 6:21 pm
Well nothing new under the sun The Beast has about a 2 sec frame rate setting and 240 lines i could go slower but be a bit too slow for the phosphor which i was more adjusting it to.
DSCN6449_x264.mp4
(3.81 MiB) Downloaded 148 times
Users browsing this forum: No registered users and 39 guests
