by Harry Dalek » Sat Sep 18, 2021 9:03 pm
Its a totally useless in the real world but to show a working version can be done with Vacuum tubes is pretty interesting ..Yes a lot of Tubes there !,hell of a power supply but then again i have noticed these computer or flip flop valve projects they run the valves on a lower voltage the 201A plate voltage is 45 volts very old tube .
Wonder if you can call this tube 555 a tube IC ?
- Attachments
- OIP.jpg (26.23 KiB) Viewed 4564 times
- uv201a.jpg (19.51 KiB) Viewed 4564 times
