I Built A Thing . . .
Postby jjester6000 » Thu Sep 23, 2021 2:47 am
]So, I've screwed around with analog television junk for quite a quite a while now, but its been quite a while since I've been to this forum.
I picked up this Sanyo VC500 PortaPak camera at a flea market recently, and I decided that I want to build myself a digital recorder for it.
Whenever I got a PortaPak camera in the past, I would have just cut the connector off, separated out the appropriate wires, and hooked the unit to a VCR (I took my RCA CC011 Storm Chasing, and recorded it using a VCR running off an Inverter).
DIGITAL VIDEO RECORDER FOR USE WITH PORTA-PACK CAMEREAS (You might find it interesting)..png
(My initial design, but not final)
I decided to use one of those FPV DVR's (for use with drones) as my recorder, as well as a 7AH SLA. I'm currently in college, so I don't have much of a work space in my apartment (Let alone many tools).
Despite this, I was able to make it happen with parts from the Auto Parts Store, a Conduit Box from Home Depot, and a $3 hot glue gun.
It's not finished yet, but it is functional.
It still needs some sort of charging regulator to avoid overcharge (I got an external A/C adapter that plugs into the cigarette lighter with a regulator built in, but I want to be able to run it off my trucks power socket) as well as a pre amp for the microphone (I can't hear shit).
I'm also considering welding on some belt loops so I can affix the unit to myself (Maximum Portability!)
jjester6000
Laboratory Assistant
Re: I Built A Thing . . .
Postby Steve Anderson » Thu Sep 23, 2021 6:04 pm
jjester6000 wrote:It still needs some sort of charging regulator to avoid overcharge (I got an external A/C adapter that plugs into the cigarette lighter with a regulator built in, but I want to be able to run it off my trucks power socket) as well as a pre amp for the microphone...
Is the 'trucks' power different? Perhaps 24V? No big deal if it is or is not. How long would you wish a 7AH 12V battery to recharge in? Assuming engine/motor running...
Mic pre-amp easy, any idea of the mic used? Dynamic, electret or other? Any details?
Also, any experience in component-level builds rather than buying 'modules'?
One final question...what are you trying to do with this project? A rather important one...it's all rather vague to me...it seems to me, buy a dash-cam and be done with it, but correct me if I'm wrong...sorry if that seems a little harsh...
Postby smeezekitty » Thu Sep 23, 2021 7:01 pm
Steve Anderson wrote:One final question...what are you trying to do with this project? A rather important one...it's all rather vague to me...it seems to me, buy a dash-cam and be done with it, but correct me if I'm wrong...sorry if that seems a little harsh...
In the same vein, vidicon cameras are particular easily damaged by exposure to direct sunlight so that seems like it would make it a bad choice for recording in a car
smeezekitty
Postby Steve Anderson » Thu Sep 23, 2021 7:21 pm
smeezekitty wrote:In the same vein, vidicon cameras are particular easily damaged by exposure to direct sunlight so that seems like it would make it a bad choice for recording in a car
In the same way the camera on Apollo 12 suffered the same fate...different type of tube though, but still subject to permanent 'burnout'..
https://www.youtube.com/watch?v=UtBMAMO11e8
Many other links to the same subject...
Now, what if that happened on 11?
Postby jjester6000 » Fri Sep 24, 2021 1:19 am
Though I do have dual batteries, its a 12V system, and I want to be able to keep the battery topped off without overcharging it (would a voltage limiting resistor do the trick?). I go storm chasing and like old cameras, so why not combine them?
I don't have much experience in component level building, in fact not too much experience with electronics projects in general; I'm good with automotive wiring, but I'm also somewhat literate in actually building circuits (I built an amplifier circuit for my crude flying spot scanner).
Also, I understand that Vidion tubes are fragile, but I made this thing able to work with many different cameras; I understand that Saticon Tubes are particularly robust against this.
jjester6000
Postby jjester6000 » Fri Sep 24, 2021 2:15 am
This video right here is part of the reason that I want to take a vidicon camera Storm Chasing
https://youtu.be/17Cd-3z5gmQ
May 17th, 1981
(The NSSL had built a sound recording probe to deploy in the path of a tornado).
(I also have a period correct truck for the job)
jjester6000
Postby jjester6000 » Fri Sep 24, 2021 8:41 am
I did a bit of work on the unit, and made it actually a bit more usable.
I added a shoulder strap as well as some connectors for an external mic (I don't need a preamp after all, the mic on the VC500 is just crap).
I also fixed up the VC500 with a new/used lens from a parts RCA CC011 (I bought the camera without a lens)
I had to modify it slightly to allow for a manual iris control, but its a hell of a lot better than the fixed zoom CCTV camera lens I was using.
Here is a video test I made with this camera:
https://youtu.be/ln_iZWvW62s
jjester6000
Postby jjester6000 » Sun Sep 26, 2021 2:21 am
So I did some more slight modifications to the camera.
I added the Mic off my CC011 parts unit, and it seriously looks pretty cool on the camera.
I also added the indoor/outdoor filter off the same camera, and it has seriously improved the over exposure issue.
jjester6000
Postby jjester6000 » Tue Sep 28, 2021 1:25 am
I got me a label maker, and its amazing how it completes the look of this unit.
I also labeled some other stuff.
Maybe I'll make a Stereo Dust Particles commercial about this unit.
http://45.59.85.254/sdp-ads/index.html
jjester6000
