dominicbeesley wrote:...The one thing I've not experimented with yet is the a3 voltage.... Cheers. Dom
I used to have a VCR138 (not 139) tube decades ago and as I recall I'm sure I was able to get the line width/spot size down to less than 1mm as I used it as part of a flying snot scanner for SSTV.
It is a different tube, a slightly larger screen and much longer but comes from the same period and uses very similar voltages.
Now I can't find any data for the VCR139 specifically, but referring to the equivalent ECR30 datasheet a1 and a3 are tied together and would be at ground or slightly positive, say +150V which would also be the average potential of the deflection plates. The cathode would sit at -650V giving a total of 800V 'across' the tube. The grid (brightness) would be up to 20V more negative still.
a2 is the focus electrode which should sit some 100 to 170V positive wrt the cathode (-550V to -480V wrt ground). All of the above I'm sure you're aware of, but put it in for completeness.
Most of these oscillographic tubes were used in this manner. I have seen somewhere that 'odd things' can happen when these older tubes are used with the cathode at or near ground and the anodes and deflection plates operated at a high positive voltage. One I have seen myself is that when touching the screen the trace moves and distorts. Who knows, if you are using this tube in this manner it might explain the poor focus?
Later tubes like the DG-xxx series had an aluminiumized coating applied to the rear of the phosphor which eliminated this and increased the brightness. Don't forget these older tubes were nowhere near as bright as more modern ones. Even the DG7-32 display elsewhere on this forum had to be viewed in subdued light, even with its aluminiumized coating.
Another point is focus current (a2), in these older tubes (pre-1945) the focus current was comparatively high. With the development of the Einzel focus system it dropped to well under 50uA (of either polarity!) It might be worth checking the divider chain for the focus anode that it has sufficient standing current.
Putting a small capacitor from a2 to the cathode would eliminate any hum/ripple on it, say 10uF/250V.
Magnetic fields....make sure there are no (50Hz) transformers, motors etc. nearby, also the LOPT might be the culprit. I might face this problem with 'The Brute'.
Otherwise at this point I'm out of ideas.
