Marcus:
Below is the text of an email exchange I had today with a fellow here in the states who has a website with some information of the Waterman S-10. He also has a schematic on how to display video on a scope. (Of course he was doing it with 525/30 NTSC video). I was asking him about how to display NBTV 30/12.5 video on it. He graciously replied with some technical information on how it might be done on this little scope.
As you can see the Waterman is not very capable... however it might just be possible to display NBTV on it. And, that would be fun!
Here's the text of the email:
Sent: Thursday, February 05, 2009 1:13 PM
To: Szasz, David A. (CSI)
Subject: Re: Restoration of Waterman S-10A Scope?
Hi Dave,
Congrats on winning a nice little 2" scope. If the seller was able to get the CRT lit then you are in pretty good shape. The tubes are probably still good. The only thing you would need to do is recap the scope then it should work fine for a while. If I recall correctly, there are probably only two 22uF 450V electrolytic capacitors and maybe 5 to 8 paper capacitors in the range of 0.001uF to 0.1uF. No need to replace the mica capacitors if there are any.
I thought about adding a Z axis to the Waterman but I wasn't too certain of the Z-axis performance because the scope is very very simple. The scope probably could handle slow TV signals, but NTSC is questionable. The Waterman has a built in sweep that can be triggered via HOR/SYN with the horizontal function set to EXT, so feed that the horizontal sync of the 30-line signal, I think that'd be 350-ish Hz or something? The vertical you'd need to build a sweep oscillator running at 12-ish Hz, could be done with tubes or transistors, take a look at my TV-Scope converter circuitry but crank down the vertical frequency from 60Hz to 12Hz or so.
If you look at the schematic for the Waterman S-10A (
http://www.electronixandmore.com/misc/waterman.pdf) then notice that the CRT grid (pin 10) connects to the brightness control via R19. Since R19 is in place, it already serves as a grid resistor so you could simply disconnect C14 from ground and feed the Z axis modulation through C14. However, I have no idea if it would even look any good. You'd need at least a 20-30V Z-axis modulation I would think, and be careful because C14 is the only isolation between you and -100 to -200V in the scope.
Let me know how your project comes along. I've been fascinated in mechanical TV for some time. I even tried building my own color 32-line camera but never really got far because the photodiodes I used need an enormous amplification gain. A PMT might do the trick. Someday...
Jon
On Feb 5, 2009, at 11:51 AM, Szasz, David A. (CSI) wrote:
> Hi:
> After several tries I have finally won an auction on Ebay for a Waterman S10A "Pocketscope."
> 1.) I would like to ask for your suggestion for the best approach to restoration of this classic device. Should I just replace all the capacitors and test the tubes to start or what? The prior owner plugged it in and the CRT still lit-up so it should be possible to get it to working order.
> 2.) Is there a simple way to modify this scope to display 30-line NBTV signals? I am into the mechanical TV hobby... but have little experience with vacuum tubes. thus the interest in the Waterman S-10. It looked simple enough for me to understand...
> Though it lacks a second channel and "Z-axis." I have seen articles on adding a second channel, so perhaps it could display very simple graphics.
> Anyway I just cant wait for this little cutie to arrive on my doorstep.
> Thanks for your advice, love your website... it's very inspirational
> thanks
> Dave Szasz - KG6KGG
Television? The word is half Greek, half Latin. No good can come of it.
C. P. Scott
