KG6KGG wrote:...then again PAL was standardized in the early 50’s, so give good old NTSC a break. In effect, if you can see the line structure of the picture, you are sitting too close to the TV!
Volker thanks for all the data, I assume that the aspect ratio was slightly landscape, correct? I did guestimate the bandwidth required and it agreed with the 500kHz mentioned above. Thanks for the offer to scan further documents but I'll be doing my usual hybrid design using tubes that are still available, I'm not sure if there is a source of German tubes, maybe in Germany but I haven't seen many elsewhere.
Dave, as you probably are aware PAL and NTSC are very closely related, PAL could almost be called 'Son of NTSC'. What confuses a lot of people is the relationship between the number of lines, the colour encoding system used and the frame/field rate. In the studio it is
very hard to tell the difference in a side-by-side comparison between 525/60 NTSC and 625/50 PAL at correct viewing distance. The problem occurs on analogue transmission where phase changes occur between the transmitter and receiver.
PAL gets around this by alternating the phase at line rate (simplification here) so a +10° error becomes a -10° error on the next line.Nothing is done about this and it is presented to the CRT (or whatever) as is. The eye and brain integrates this and we get the impression of the correct colour.
There is no technical reason why PAL couldn't be used at 525 lines and NTSC on 625 lines. There is also the choice of sub-carrier frequency, 3.58 or 4.43MHz. There is a reason for these frequencies but I'm not going into that here. Some South American countries do use some odd combinations. NTSC colour was experimented on 405 lines in the UK but was not put into service with the impending change-over to 625 lines.
I'm not even going to mention SECAM, heck I just did!...and as usual I've wandered off-topic!
