Panrock wrote:Or....simply buy the two-quid calculators and strip them...Steve_O
If that fits the budget including the time to do so then go for it! Assuming they meet your requirements.
What I have found is that you tell the distributor that you wish to do a 'pilot run' of say 25 for assessment and later say that the project was canceled or a change of design was implemented. This is quite normal. You can then do another 'pilot run' using the same devices but with a 'revamped' design. There's always more than one way to skin a cat.
A lot of my 'real work' is in prototypical devices where I only need a few but my client might wish to order thousands, this is true and the way forward in a design. Whatever you are pulling together maybe a hot seller, they just don't know. And presumably at this stage neither do you.
One of my clients has ordered 4.5 million serial EEPROMs as a consequence of one of my designs over the past two years or so. Made in China, and the market? China.
