Page 1 of 1
The Venerable CA3306.
PostPosted: Mon May 01, 2023 4:19 pm
The venerable CA3306 may soon be a thing of the past. It's a 6-bit analogue-to-digital converter that can sample at up to 15MHz with a simple parallel data output. It has been used often for converting 525/625 to NBTV, SSTV or whenever FSTV needs converting to another format. It's now considered obsolete and not so easy to obtain these days. A pair can be cascaded to get a 7-bit output.
It appeared in Peter Smith's 625 to NBTV 30/32-line converter, CQ-TV 189, year 2000, and also in the NBTVA newsletter around the same time, Vol. 25 No. 3. There are more modern replacements, and generally of at least 8-bits, but they're either expensive and/or in SMD packaging and possibly static sensitive. The CA3306 is in a 18-pin DIL package - easy for us lot.
I've got a few items on my 'NBTV TO DO' list, an update of Peter's converter is one of them. I did make a start on this in 2013, but something must have interrupted me. This has floated to near the top of the list as I'm going to need a source of NBTV soon...quite urgently in fact.
The reason for this posting is a local supplier has around 60 CA3306's in stock, I imagine that once gone, that will be it! They're made by either Harris, RCA or Intersil, though it's pot-luck whichever you get, they should all be the same functionally anyway. Cost? Thai Baht (THB)102.00 each inc. local VAT, =GBP2.37, US$2.98. A 'centralised distribution point' in the UK would make sense and reduce postal costs from Thailand to the UK.
Those interested in getting a few let me know and we'll try and organise things. Anyone care to act as the 'centralised distribution point' in the UK? I will test all before shipping.
As an aside, there was an 8-bit version, the CA3308, but no luck with finding a supplier of those...
Datasheets that I have for the CA3306 attached...
...also one for the CA3308 for interests sake, be sure not to mix them up, the type numbers CA3306 and CA3308 look very similar at a quick glance...
Cricklewood Electronics in the UK list the CA3306, but "Not available at present. Please check at later date." I doubt they ever will be available now...and no price mentioned either...
It appears that the LM1881 FSTV sync-separator is going the same way, it has been replaced by a version that can also handle HDTV. Time to stock up on those while you can...
CA3306_Harris.pdf
(146.79 KiB) Downloaded 984 times
CA3306_Intersil.pdf
(352.14 KiB) Downloaded 929 times
CA3308-RCA.pdf
(194.73 KiB) Downloaded 954 times
Re: The Venerable CA3306.
PostPosted: Mon May 01, 2023 5:42 pm
by Dave Moll
Steve Anderson wrote:...also one for the CA3308 for interests sake, be sure not to mix them up, the type numbers CA3306 and CA3308 look very similar at a quick glance...
Just remember that the final digits are the number of bits.
PostPosted: Wed May 03, 2023 4:17 pm
...a follow on...
The replacement for the LM1881 is the LMH1980 from TI and others. It on paper appears to be a better device all-round for standard 525/625 and also handles various HD formats. Downsides - it is more expensive, though not outrageously so. BUT, it's in a SMD package of 10 pins with a 0.5mm pitch! As good as useless to us!
LMH1980 TI.pdf
(1.13 MiB) Downloaded 984 times
