AncientBrit wrote:'enough for perfect decoding' but at the expense of a PLL,
Steve Anderson wrote:Hi Troy,
That certainly is an ambitious project and I wish you the best of luck with it. I will be watching this closely.
Can I suggest you start a new thread in the 'Off Topic' section for this when you get going. As you point out it's not NBTV but it is most definitely 'of technical interest'. It also might reduce confusion between the two projects.
When (if?) you receive that data from Japan perhaps you could post it in the new thread? (Assuming there's no copyright issues). I sure would be interested.
Users browsing this forum: No registered users and 71 guests
