Steve Anderson wrote:Oh heck! I didn't realise you were actually building it! As I said, it was just an idea in my head, I've never built or experimented with it myself.
Steve Anderson wrote:I'm fairly certain it will work, the only proviso is that there are 31 sync pulses and no glitches or other rubbish mixed in with them. But that's generally true of most frame sync detection arrangements.
Viewmaster wrote:Of course with this Niptrix display, it should work OK with only the 31 pulses coming off the sync sep. Just that the 1st line of LEDs would not be clocked and so missing.
Steve Anderson wrote:Viewmaster wrote:Of course with this Niptrix display, it should work OK with only the 31 pulses coming off the sync sep. Just that the 1st line of LEDs would not be clocked and so missing.
I don't quite grasp that, I can't see any reason why line 1 (presumably) would be omitted. The whole raison d'être for this sort of arrangement is to ensure that the framing is precise which includes displaying line 1 in its entirety and correctly positioned.
But then again I could be missing something...not just line 1.
Viewmaster wrote:.........I inserted the first vib and the counter and switched on.........big smoke from the vib and the 12v fuse blew
Steve Anderson wrote:On second thoughts maybe I won't. As it forms part of the NIPTRIX perhaps it's better included in that. That's assuming Albert will be submitting this sometime.
Viewmaster wrote:...it has not been tested in combat yet, so any publication may be premature
Steve Anderson wrote:Viewmaster wrote:...it has not been tested in combat yet, so any publication may be premature
Yes, agreed. being the positive-minded individual I am I'm thinking that this will in due course work and that a submission would be made for publication. So I'll leave it up to your good self to include said arrangement.
Steve Anderson wrote:[
I've not had any contact from Jeremy in a while so I don't know what his status is regarding enough material for the newsletter. But it's clear that this is not going to be ready for the usual December issue. In conjunction with a demonstration at the convention next April would be ideal...but things in life don't generally work like that...
Over 3,000 more joints to be done so we shall see for convention in time.
Users browsing this forum: No registered users and 100 guests
