Klaas Robers wrote:What type of noise are you searching for Steve? The type of noise that a Geiger-Mueller counter makes? Or ignition noise of a motor bike, which has a more repetitive character?
Klaas Robers wrote:What is your aim? Where do you want to use it for?.
As random as possible.Klaas Robers wrote:How random should it be?.
AncientBrit wrote:I think you'll need to LPF the noise to restrict it to the region of say 5Hz to 100Hz, then as you say use this to trigger a mono with a short tc to produce the impulse type signal you're after.
Users browsing this forum: No registered users and 28 guests
