MUTR pictures CD with upright and inverted video
Postby Klaas Robers » Sun Jan 16, 2011 10:17 pm
Here are the wave files for the MUTR CD with upright and inverted video.
NEW !
In the mean time 8 new MUTR files became available and I processed all the MUTR files. The video amplitude and the black level was adjusted, sub-black spikes were clipped off and new really continuous sync was added to all 17 files.
The new files MUTR10 to MUTR17 are too long to place here. Zipping them gave almost no gain in size, but it did on the files MUTR01 to MUTR09. So I will post these files as ZIP-files.
You will find 19 .wav files.
MUTR01 to MUTR09 has the NBTV with upright video,
MUTR20 is a cross-over track,
MUTR21 to MUTR29 has the NBTV with inverted video.
- Download the zip-files and
- unzip the files,
- this will give you .wav-files MUTR01 to MUTR09 and MUTR20 to MUTR29.
- Prepare an audio recording list with the 19 files in alpha numerical increasing order.
- Record an audio type (no data!) CD-R disc in the mode DISC AT ONCE !
This should provide you with a CD of 19 tracks and a total playing duration of 11':36" with continuous video, that is with no interruptions, no pauses in between the tracks. You may check that by listening at the sound on the left (= video) channel of the CD.
The MUTR televisor wil synchronise and display the video contents of CD-tracks 1 to 9, or CD-tracks 11 to 19, depending on the polarity of your CD-player output. In fact all other televisors should do this as well.
Later: sorry, the MUTR05.zip is now at the bottom of the list, as I had to update that file. I found out that the previous file was the unzipped .wav file and much larger than the correctly zipped version of MUTR25.
Anyway it is remarkable that the zipped files of the files with upright video (MUTR01 to MUTR09) have different lengths than the files with inverted video. Ads Wave files they have exactly the same lengths. It looks as if the zip algorithm does some kind of guess and the file can be longer or shorter depending on the guess. Compare MUTR25 and MUTR 05, different lengths, but unzipped they are both 7925 kB. The only difference is the polarity of the video and audio.
MUTR01.zip
Zipped file MUTR01.wav
(898.78 KiB) Downloaded 877 times
MUTR02.zip
Zipped file MUTR02.wav
(302.07 KiB) Downloaded 919 times
MUTR03.zip
Zipped file MUTR03.wav
(357.71 KiB) Downloaded 870 times
MUTR04.zip
Zipped file MUTR04.wav
(1.11 MiB) Downloaded 826 times
MUTR06.zip
Zipped file MUTR06.wav
(3.82 MiB) Downloaded 830 times
MUTR07.zip
Zipped file MUTR07.wav
(6.73 MiB) Downloaded 918 times
MUTR08.zip
Zipped file MUTR08.wav
(4.1 MiB) Downloaded 895 times
MUTR09.zip
Zipped file MUTR09.wav
(4.66 MiB) Downloaded 844 times
MUTR20.zip
Zipped file MUTR20.wav
(305.41 KiB) Downloaded 791 times
MUTR21.zip
Zipped file MUTR21.wav
(899.48 KiB) Downloaded 881 times
MUTR22.zip
Zipped file MUTR22.wav
(302.57 KiB) Downloaded 750 times
MUTR23.zip
Zipped file MUTR23.wav
(358.81 KiB) Downloaded 907 times
MUTR24.zip
Zipped file MUTR24.wav
(1.16 MiB) Downloaded 814 times
MUTR25.zip
Zipped file MUTR25.wav
(530.97 KiB) Downloaded 818 times
MUTR26.zip
Zipped file MUTR26.wav
(3.82 MiB) Downloaded 835 times
MUTR27.zip
Zipped file MUTR27.wav
(6.73 MiB) Downloaded 789 times
MUTR28.zip
Zipped file MUTR28.wav
(4.1 MiB) Downloaded 820 times
MUTR29.zip
Zipped file MUTR29.wav
(4.66 MiB) Downloaded 770 times
MUTR05.zip
Zipped file MUTR05.wav
(509.46 KiB) Downloaded 816 times
All MUTR files on the web
Postby Klaas Robers » Sun Feb 16, 2014 3:30 am
To help Daan and Joost, two Dutch high school boys, living in Haarlem the Netherlands, and who made a Nipkow disc televisor monitor for their Physics "Research Task", I placed the complete contents of the MUTR disc on the web. Now they can make their own MUTR disc.
Go to http://www.nbtv.org/MUTR-disc/ and read how you can download all files and 'burn' your own 37 tracks CD with upright and inverted video signals.
Return to Images and Sound
