AncientBrit wrote:Morning Harry,
Fascinating reading your experiments.
Keep up the good work.
Not sure how you find the time for all this plus work!
AncientBrit wrote:Hi Harry,
3 day week!! Not bad.
Happy experimenting,
gary wrote:Harry I am probably going to make a goose of myself here but my excuse would be I am having trouble interpreting your images, also it maybe you are just trying to show the light path in some way I don't quite understand, but whilst the direction you are showing the beam of light is correct for when it is operating as a camera, surely you would want to reverse that (i.e. from the source to the line scanner to the frame scanner). That way you would project a raster on the area you would be "scanning" when in camera mode ( or "spotting" if in FSS mode). If that raster is correct then the reverse (i.e. camera mode) would be correct.
In other words there is a "duality" in this type of system whereby if you replace the photo detector with a light source you change a camera into a projecting monitor (or FSS if the light source is unmodulated) - and vice versa.
Users browsing this forum: Google [Bot] and 41 guests
