smeezekitty wrote:Hard to tell based on the camera exposure but I bet it will be bright enough. The diffusion is okay but you will likely see the diffuser texture through the picture
FlyMario wrote:smeezekitty wrote:Hard to tell based on the camera exposure but I bet it will be bright enough. The diffusion is okay but you will likely see the diffuser texture through the picture
Yes, I agree. Damn... I guess I better just get some plastic as Harry suggests. That diffuser texture will surely be part of the video.
Harry Dalek wrote:Here is where i used the idea well at least showed what i was up to on one of the 2 drum designs with the mechanical sawtooth slit drum
viewtopic.php?f=1&t=1486&hilit=drum+monitor&start=60
FlyMario wrote:
That a milk jug that you used as the diffuser? Recycling!
Steve Anderson wrote:Your problem with the Chinese-made module maybe one or both of two things. First, depending on the distance from the disc to the LED and detector, they may need angling in towards each other for better coverage and sensitivity - looking at the photo that may be difficult to achieve. A lot of these devices have a beam-width/sensitivity curve of only some +/-10 degrees.
Second is if the disc markings for this are printed (laser or ink-jet) rather than 'done in hardware' a lot of inks (black in this case I assume) are reflective at IR.
I hope this helps...
