The levitating scanner
Postby DrZarkov » Fri Nov 23, 2018 1:42 am
In the German edition of the Make:Magazine there is an article about a toy with with spinning, levitating LEDs. Even if you don't understand German, the pictures and circuits will speak for themselves: https://www.heise.de/make/artikel/Levit ... 27206.html
I wonder if it would be possible to use this (or a modified) version of this construction as a mechanical television scanner. Maybe not with normal horizontal scanning, but with an interlace left up to right down - right down to left up?
Re: The levitating scanner
Postby Harry Dalek » Sat Nov 24, 2018 8:53 am
you can use google translate...sort of works
https://translate.google.com/translate? ... edit-text=
Users browsing this forum: No registered users and 36 guests
