Markd wrote:What a great project. Look forward to further developments.
Gregory wrote:...I had to bend the IC legs up and loaded them upside down...
Steve Anderson wrote:Oops, but so easy to do! I suggest adding some text to be etched, say, "Gregory 2021" (without the quotes), or a project name, circuit function, even IC pin-numbers on each corner of the chips, anything that makes it obvious that something isn't quite right...slightly more work, but it saves these glitches...
Harry Dalek wrote:Good to see its coming together you really had to start from scratch !
Noticed the original system had problems may be why it wasn't used again or just the war and CRT its time was up ,not here ! i will like to she your beauty display !
Harry Dalek wrote:Looks very nice ! very jealous !
Gregory wrote:Harry Dalek wrote:Looks very nice ! very jealous !
Harry I wouldn't be jealous yet - it might never work!
Then nest step is modifying the original frame scan mirror to fit the new televisor, by widening the base spacer and cutting a new wider set of mirror plates, whilst using the existing octagonal side support panels.
Users browsing this forum: No registered users and 65 guests
