NBSC Player / Recorder
Postby dominicbeesley » Thu Jul 23, 2009 11:50 am
Hello all,
Hello all,
Just a quick message to say there is a new version of the NBSC Playback and Recording software at http://www.authorityfile.co.uk/NBSC/dow ... fault.aspx
New this version:
Much smaller install file!
B&W Baird 30 / 48k
B&W Baird 60 / 48k
Records + Play CCNC colour NBTVA 32 / 44.1k
Records + Play CCNC colour Tekade 60 / 48k [this should probably be changed to 96k]
Records + Play CCNC colour Tekade 30 / 48k
Also there are a set of low bandwidth NBSC colour standards, these are thus far experimental and a bit ropey but will hopefully enable colour broadcasts over an amateur link at some point in the future.
Dom
dominicbeesley
Postby AncientBrit » Thu Jul 23, 2009 5:32 pm
Nice site Dom.
A lot of work has gone into this I feel,
Well done,
Postby dominicbeesley » Thu Jul 23, 2009 9:43 pm
Thanks Graham,
I'm sure if I spent as much time on my real work I'd be rich by now...
I'd love to hear back from anybody with any reports on using the player or the recorder softwares. Positive or negative! So far I've only had one report back about the recording software....so I'm not sure whether it is working for anyone else!
Dom
dominicbeesley
Postby holtzman » Sat Jul 25, 2009 7:19 am
Thank you very much Dom!
The player works now on 60 lines and I can compare my disc results to an "ideal" digital picture.
Now it's possible to watch clips converted to 60 lines and to see what impact remains after such reduction.
The bugs found: 1."Capture frame" stalls the programm. 2.Playback position cursor, when touched, crashes Windows XP and I get automatic PC restart :? Once not using these features, everything is fine and works well.
Unfortunately my NBTV 60 lines project is on hold now, but I'm really happy to have your player and it inspires me to continue with 60 lines!
holtzman
Postby Marcus » Sat Jul 25, 2009 11:56 am
Thanks Dom,
I have installed it and had a bit of a play, it is very easy to use!
I'll fire up my mirror screw a bit later and post the results.
Thanks heaps, for doing the tekade standard in there!
Marcus
Postby dominicbeesley » Mon Jul 27, 2009 7:12 am
Thanks both,
I'll have a look into the problems reported by Holtzman and get back next week hopefully
Dom
dominicbeesley
Postby Marcus » Thu Jul 30, 2009 10:41 pm
Hello Dominic,
When using 'default' on Tekade for sound capture it crashes the program.
Not sure if I'm using it right thoug, should default capture the sound from youtube?
Thanks, my single transistor LED driver isn't working so as soon as I get the LED array running of the radio I post picks.
Thanks again.
Marcus
Postby dominicbeesley » Thu Jul 30, 2009 11:03 pm
Hi Marcus,
Have you enabled loop back sound? Follow the link at http://www.authorityfile.co.uk/NBSC/art ... struct-9.3.
If that doesn't work does it give an error message at all?
Dom
dominicbeesley
Postby Marcus » Tue Aug 04, 2009 11:17 pm
I got it working I just needed to enable stereo mix in the audio out settings.
Working perfect now, it is great to be able to convert stuff right off youtube.
Thanks again Dominic.
Marcus
Re: NBSC Player / Recorder
Postby Jakub Gracik » Wed Mar 07, 2018 6:04 am
Hello, i have issue with NBSC Player and NBSC Recorder.
I cannot open NBSC Recorder, it just crashes.
But NBSC Player shows error and after clicking continue kinda works...
I am getting this error:
Code: Select all
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.BadImageFormatException:  nie je platnou aplikáciou Win32. (Exception from HRESULT: 0x800700C1)
   at NBSCPlayer.Form1.Form1_Load(Object sender, EventArgs e)
   at System.Windows.Forms.Form.OnLoad(EventArgs e)
   at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
   at System.Windows.Forms.Control.CreateControl()
   at System.Windows.Forms.Control.WmShowWindow(Message& m)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.8762 (QFE.050727-8700)
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll
NBSCPlayer
    Assembly Version: 1.1.3443.25630
    Win32 Version: 1.1.*
    CodeBase: file:///C:/Dominic%20Beesley/NBSC%20Player/NBSCPlayer.exe
    Win32 Version: 2.0.50727.8015 (FX35W81RTMGDR.050727-8000)
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
    Win32 Version: 2.0.50727.8770 (QFE.050727-8700)
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
    Win32 Version: 2.0.50727.8019 (FX35W81RTMGDR.050727-8000)
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
WindowsFormsControlLibrary1
    Assembly Version: 1.1.3443.25629
    CodeBase: file:///C:/Dominic%20Beesley/NBSC%20Player/WindowsFormsControlLibrary1.DLL
NBSCLib
    CodeBase: file:///C:/Dominic%20Beesley/NBSC%20Player/NBSCLib.DLL
NBSCLib2
    Assembly Version: 1.1.3443.25627
    CodeBase: file:///C:/Dominic%20Beesley/NBSC%20Player/NBSCLib2.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Note:
OS: Windows 8.1 64bit in Slovak
RAM: 16GB RAM
CPU: 3.2GHz Intel Core i5
Jakub Gracik
Postby smeezekitty » Thu Mar 08, 2018 9:21 am
See if this works
NBSCPlayer.zip
(28.12 KiB) Downloaded 277 times
Postby dominicbeesley » Thu Mar 08, 2018 12:33 pm
Hi Jakub,
My post from earlier today must have gone missing. Please let me know if Smeezekitty's special version worked or not. I just spent a couple of hours updating the software here but it's not quite finished. The version on the website doesn't seem to work with newer 64 bit computers...sometimes. The version I'm making now should do and will hopefully be a little bit better too! I'll post back this weekend with an update.
D
dominicbeesley
Postby dominicbeesley » Fri Mar 09, 2018 1:59 am
If you're still having troubles this version might work better. It has been updated to use the newer v4.6 .Net Framework and SlimDX instead of the quite old DirectX managed code libraries.
Let me know how you get on!
I'll try and get round to speeding this up a bit as it tends to struggle when playing back with bot the scope and vectorscope running even on my fastest machine.
D
NBSCPlayer-v1.1.2.zip
(1.29 MiB) Downloaded 285 times
dominicbeesley
Postby Jakub Gracik » Fri Mar 09, 2018 5:47 am
So Thank very much as it now works now :) !!!
But I've found some bugs:
1. Recorder cannot record to file, and same is direct to speakers:
Code: Select all
System.NullReferenceException: Object reference not set to an instance of an object.
   at ScrapeNBSC.Form1.timer1_Tick(Object sender, EventArgs e)
2. Smooth in Player doesn't work, maybe it works or it isn't supposed to work :D
3. Playback position control in Player doesn't work either(or maybe i don't know how it works).
So again, thank you that you fixed it and got it working..
Jakub Gracik
Postby Harry Dalek » Fri Mar 09, 2018 12:58 pm
Hi Dom i use windows 7 the new frame work 4,6 will not load on this computer with windows 7 i suppose ,i still use your older version and works well .
