PCB Discs..
PCB Discs..
Postby Steve Anderson » Thu Apr 26, 2007 8:05 pm
Gents,
Has this been done before?
PCBs can be made with great accuracy, to within 0.02mm and hole sizes down to well under 1mm.
A single sided PCB (in this case unetched) can be shaped and drilled to great tolerances, including circular. Using a fibreglass based board would ensure that it's flat and rigid.
In a one-off application this is expensive, but with a dozen or so (remember no etching required) it should become feasable in terms of cost.
Anyone had ideas in this direction?
Postby DrZarkov » Thu Apr 26, 2007 11:48 pm
Isn't PCB too thick? But it would be an interesting material, easy to work with.
PCB Discs.
Postby Steve Anderson » Fri Apr 27, 2007 1:01 pm
For a single-sided fibreglass PCB the 'standard' thickness is 1.6mm. But others are available, down to less than 1mm.
How thick is the Darvic sheet as stocked by the NBTVA?
Re: PCB Discs.
Postby gary » Fri Apr 27, 2007 1:28 pm
Steve Anderson wrote:For a single-sided fibreglass PCB the 'standard' thickness is 1.6mm. But others are available, down to less than 1mm.
Using a micrometer mine measures .6 mm.
Preliminary investigations here in Sydney indicates the cost would be
similar to having them CNC or Laser cut from thin aluminium, although I concede that I have yet to source aluminium sheet less than 1mm (Peter Yanczer, I think, mentioned 'engraving stock', does anybody know where this is normally obtained?) but the holes can be countersunk.
Aluminium discs.
Postby Steve Anderson » Fri Apr 27, 2007 2:18 pm
The problem with thin aluminium is that it's a malleable material it's very easy to bend or warp a disc, either during construction or transportation. Trying to 'flatten' it out again is unlikely to be successful.
Whereas a fibreglass disc is brittle and takes a lot to bring it to breaking point. Similar to the difference between cast iron and steel.
I don't know the properties of Darvic, I'll do a bit of Googling...
Re: PCB Discs.
Postby Viewmaster » Fri Apr 27, 2007 6:24 pm
gary wrote:Preliminary investigations here in Sydney indicates the cost would be
similar to having them CNC or Laser cut from thin aluminium, although I concede that I have yet to source aluminium sheet less than 1mm .
The 'Aluminium Shop' here in the UK does .7mm in various grades and sizes. You could ask them if they ship to Australia for you.
http://www.thealuminiumshop.co.uk/acata ... et_30.html
I recently bought ali sheet on eBay .8 mm so worth looking there too.
Re: Aluminium discs.
Postby ac7zl » Sat Apr 28, 2007 6:29 pm
I think fiberglass PCB material would make an excellent wheel.
I would expect that the principle loading a nipkow disk sees is radial and tensile in nature. Glass fibers have excellent tensile properties, and can exceed the performance of steel, at reduced weight to boot.
The one problem I can envision is that fiberglass may not be sufficiently opaque. You'd probably have to paint it. If it has copper cladding, of course, you're all set.
Pete
Steve Anderson wrote:The problem with thin aluminium is that it's a malleable material it's very easy to bend or warp a disc, either during construction or transportation. Trying to 'flatten' it out again is unlikely to be successful.
ac7zl
Mad Scientist
PCB discs.
Postby Steve Anderson » Mon Apr 30, 2007 12:26 pm
I was thinking of unetched single sided PCB, with the copper layer it should be opaque enough I would have thought.
Users browsing this forum: No registered users and 102 guests
