Andrew Davie wrote:Today I went out and bought a BD139, snipped out the incorrect transistor and soldered in the replacement. If you'd ask me what was the absolute LAST thing I would expect to happen, it would be that the LEDs would still light up...
The LEDs still light up! I can't see a single thing different in how the circuitry "works" compared to the other transistor. Time to start suspecting my soldering joints, no?
Finally, I measured the voltage across the C/B/E of the transistor. Did I put it in backwards, perhaps? I put the writing such that it was facing me with the left pin closest to the LED matrix input.
From the "left" to "middle" measured 1.47V with no input.
With input from CD (ie: signal) this lifted to 1.52V
from the "left" to "right" measured 1.4V/1.52
from the "right" to "middle" measured 0V
So, that's it for another night. A few steps forward, some steps backwards. I'm learning a bit every day, but it's clear to me now that these boards and debugging them is not a learner's job. I'll get there in the end
Steve Anderson wrote:Just a suggestion...if you really want to make a start in learning electronics may I suggest a book written by Horowitz & Hill, called 'The Art Of Electronics'. ISBN 0-521-37095-7 (Hard-back version)
Steve Anderson wrote:Andrew,
Yes, US$141 is absurd, but even at that price it is really well and truly worth it! You'll have no need for any other reference material except for recent developments since the last publication. (pdf files from the component suppliers cover that).
If anyone is wondering, no, I have no connection with Cambridge Unversity Press or the authors.
Andrew Davie wrote:One expected a certain amount of standardisation. Now I know I need to check these things. How inconvenient -- and why on earth don't they actually mark the pinout on the part itself? Backwards it is. I'll reverse it tonight, and try once again
Andrew Davie wrote:Andrew Davie wrote:One expected a certain amount of standardisation. Now I know I need to check these things. How inconvenient -- and why on earth don't they actually mark the pinout on the part itself? Backwards it is. I'll reverse it tonight, and try once again
I switched around the transistor, and the LEDs *still* remain fully lit (though there is a very slight variation when playing with the brightness knob). The waveform across the LED array looks basically the same... I'm really starting to get a bit frustrated with this lack of progress. There must be something obviously wrong but I can't see it. My first real question, though, is that given there's a (rough) sine wave showing at the LED... where the hell is this coming from?!! The power input is a ripple-free DC 12V, rectified at both ends of the circuits (that is, the power to the LEDs is rectified 11.8V ripple-free) and the power to the NBTV circuit boards is a ripply 17V, but internally rectified to 12V on those boards.
I suspect some subtle part substition again. Looks like it's going to be a difficult debugging time ahead
gary wrote:Can you tell us what the magnitude and frequency of the wave form across the LED array is please.
Can you also measure (this is important) what the signal at the base pin of the transistor is (magnitude and frequency if any).
This could be mains hum being picked up and amplified through grounding errors so that is worth checking.
The other possibility is that one of the op-amps is oscillating so also check on the output of each op-amp.
Welcome to the wonderful world of electronics! At least you will have learnt how much there is to learn at the end of it.
