Panrock wrote:Something that I've been wondering about... Since the greatest overload will only have occurred at the final dynode or dynodes, could a 'ruined tube' in fact still be used, but with a lower output, by simply taking the signal off at an earlier dynode rather than the anode ? Steve O
AncientBrit wrote:In the Hamamatsu manual you attached a few days ago there was an interesting circuit arrangement where the dynodes were fed directly off the taps in a Cockcroft Walton multiplier, thereby removing the need for a tapped divider. Regards,
Steve Anderson wrote:This was partly prompted by Steve O's observation of low-level noise in his colour camera and monitor system. With the exhibition of this apparatus at the weekends convention I wonder how many noticed it?
Steve Anderson wrote:PMTs have a reputation as being noisy and 'contrasty', this really shouldn't be so. Their output is as linear as any photodiode with a noise floor that beats the pants off semiconductors. .
Klaas Robers wrote:....if you illuminate a PMT with very low level light, e.g. an LED at a few micro amps, you might see noise due to the individual photons. ..
Steve Anderson wrote:So returning to where this all started, Steve O has simply got to ramp up the illumination of the subject to keep the noise to an acceptable level. Remember Bairds' subjects were almost roasted alive by the lights. Here that can be reproduced simply by sitting outside in the sun at midday...
Users browsing this forum: No registered users and 101 guests
