This is my first time posting to this forum, and I have read some of the posts related to the topic of displaying NBTV signals on CRTs. I decided to join because I'm having difficulty with my display project and I'm hoping you can help me out.
Here's the story: I wanted to record video images onto audio cassettes and reel-to-reel tape, and I needed to build a device that would display the playback signal coming from the tape deck. I build exclusively with tubes (which you would know if you saw my YouTube channel) so I started with a converter box for displaying on a Heathkit IO-12 scope. After a modification to the front-end circuitry of my converter, I was able to get a pretty good image from my Akai reel-to-reel. I have no interest in 3 things: playback from the computer soundcard (defeats the purpose of displaying NBTV in my opinion - why watch low-definition unless there's a reason, like it was recorded on audio tape. Computers are used for too much stuff in my opinion), 32-line display (unusual aspect ratio and low resolution), and mechanical scanning (I'm only interested in electronics). Having said that, I'm having trouble with the electronic scanning specifically.
The 12.5 Hz vertical sweep is really giving all my oscillators a hard time with linearity. I've built
8 configurations of different oscillators in an attempt to fix the linearity issue, and none have come close to a good result. Here is what I've tried so far: positive-slope ramp mulitivibrator using 12AT7 with tied cathodes to a common resistor, "Heathkit" style negative-slope multivibrator with the R and C in the cathode circuit of the second triode (12AT7), standard thyratron circuit, Jean-luc's posted thyratron schematic for "Horisontal Timebase," a feeble attempt at a pentode plate load for the previous thyratron circuit (with plenty of exploded resistors and burned up pots!), a phantastron used in the "Toy CRO" project I found online (I changed some values around, but no luck), and even two solid state ramp generators using a 555 timer chip, one with a single transistor for charging the cap, and another using a "current mirror" using 2 transistors. I even tried using Audacity to generate a sawtooth tone at 12.5 Hz to see what it would look like. The waveform is perfectly linear on the computer's sample plot in the program window, but the soundcard's output very much follows the typical RC time curve when viewed on the scope.
After tweaking values in all the circuits, I've made the following observations: increasing the frequency will GREATLY improve the linearity, producing almost a perfect sweep in most of the circuits, especially the thyratron and "Heathkit" multivibrator. However, decreasing the frequency back to 12.5 Hz re-introduces non-linearity, even in the so called "constant current" circuits, such as the two solid state circuits. Opposite extremes of R and C to produce the same time constant have practically no effect on linearity.
Here's what I know from what I've read:
The initial portion of the RC time curve is more linear than the entire curve, so that part should be used. This makes sense, especially when increasing the frequency: it gives the thyratron less time to reach maximum charge on the cap and uses the initial part of the RC time curve. BUT, that also increases the frequency to too high a value. Here's a picture of one cycle produced by Jean-luc's thyratron circuit running at 12.5 Hz:
Notice that it starts to go flat, but is cut short by the thyratron firing at this point. This shows the concept, but I wish I could scoot that point back a little more to get rid of the "tail" on the curve. This is the most linear wave I've been able to produce.
The next photo shows a raster using this curve. The bunching up of the lines becomes very apparent at the top:
Note that the scope does not have an option to reverse polarity, so the raster is scanned upside down by this positive-sloping ramp. This forms the picture as played back from my Akai:
When dealing with such a low resolution, every line needs to be viewable, and a picture with this much distortion is just not watchable.
I also know that, in theory, a constant-current source for charging the cap *should* produce a *perfectly linear* ramp. Hmm...then why did the solid state circuits not do this using the two types of transistor circuits to regulate the cap's charging current? I just don't get it. This is one of the MANY reasons I don't believe in theory. I'll probably get in trouble for saying that, but it's been my experience that theory is basically worth nothing...
With this being my experience, here is my question: can someone please post a practical schematic of a thyratron relaxtion oscillator using a pentode as a constant-current source for charging the capacitor? Knowing the idea and theory hasn't helped me, so I'd like to see it as a circuit that actually WORKS the way it's supposed to!
Bryan
