Steve Anderson wrote:The timing I mentioned earlier in this thread for 120-lines was a suggested starting point. If I can find some data on the TeKaDe system I'll perhaps go with that rather than introduce yet another 'standard'.
P.S. Having a hard time of finding on-line TeKaDe data, anyone have any they can post here?
Steve Anderson wrote:One of things I think could well be a stumbling block when using a PWM system at low MHz rates may be the response time of the LEDs/Luxeons. I think the red and green ones may be OK, but I'm not sure about the blue variety.
I recall Klaas mentioning that there is a visible delay in the switching speed of supposedly white LEDs due to the UV-excited phosphor. Whether this applies to the blue-only LEDs I don't know...I guess I should bone-up on their operating mechanism and/or pour over some datasheets.
Steve Anderson wrote:I also presume that the WC-01 doesn't do any Gamma-processing, I wouldn't expect it to unless specifically mentioned. This we'll have to address, Klaas's "One-device Drivers" are looking very attractive right now...
...a few more thoughts thrown in the air...
Steve Anderson wrote:Where I'm stuck is on the biasing for this, so a few questions for Darryl...
Darryl, are the mechanical RGB outputs on the WC-01 DC-coupled or AC coupled? If DC what is the nominal black-level voltage?
What (if any) is the reference (sync) signal output in this mode?
I'm trying to ensure this will work with the WC-01 as well as other sources.
tubesrule wrote:The sync output is a 0 to +3.3V signal that can be either a square wave or a sine wave. You can further select it to be either a line, frame or mains frequency reference.
Panrock wrote:tubesrule wrote:The sync output is a 0 to +3.3V signal that can be either a square wave or a sine wave. You can further select it to be either a line, frame or mains frequency reference.
Darryl, are the line and frame pulses available separately or can it be arranged for the frame pulse to interrupt the line pulses?
Users browsing this forum: No registered users and 42 guests
