gary wrote:Just a small amount of drift now Harry, 1 sample in 90.
This may be unavoidable, but can I confirm with you that you actually set the recorder to RECORD at 48kHz, and not at some other rate and then converted to 48kHz when you saved it? because that is just as bad. I don't think that is what you did but I just want to be absolutely sure.
Hi Gary
Yes it asks what record rate .....i put in 48000 mono ...
on save it asks the same but also asks to save as 8 bit 16 32 i think 64 i just kept it as 16 i was not sure on that one ?
Was the crystal dead on 400hz gary ? i can see with your software it looked like there was a tiny amount of drift as you say .
I will try and set up to record the reflective sensor.
