Steve Anderson wrote:Just a suggestion...if you really want to make a start in learning electronics may I suggest a book written by Horowitz & Hill, called 'The Art Of Electronics'. ISBN 0-521-37095-7 (Hard-back version)
Steve Anderson wrote:Andrew,
Yes, US$141 is absurd, but even at that price it is really well and truly worth it! You'll have no need for any other reference material except for recent developments since the last publication. (pdf files from the component suppliers cover that).
If anyone is wondering, no, I have no connection with Cambridge Unversity Press or the authors.
Andrew Davie wrote:One expected a certain amount of standardisation. Now I know I need to check these things. How inconvenient -- and why on earth don't they actually mark the pinout on the part itself? Backwards it is. I'll reverse it tonight, and try once again
Andrew Davie wrote:Andrew Davie wrote:One expected a certain amount of standardisation. Now I know I need to check these things. How inconvenient -- and why on earth don't they actually mark the pinout on the part itself? Backwards it is. I'll reverse it tonight, and try once again
I switched around the transistor, and the LEDs *still* remain fully lit (though there is a very slight variation when playing with the brightness knob). The waveform across the LED array looks basically the same... I'm really starting to get a bit frustrated with this lack of progress. There must be something obviously wrong but I can't see it. My first real question, though, is that given there's a (rough) sine wave showing at the LED... where the hell is this coming from?!! The power input is a ripple-free DC 12V, rectified at both ends of the circuits (that is, the power to the LEDs is rectified 11.8V ripple-free) and the power to the NBTV circuit boards is a ripply 17V, but internally rectified to 12V on those boards.
I suspect some subtle part substition again. Looks like it's going to be a difficult debugging time ahead
gary wrote:Can you tell us what the magnitude and frequency of the wave form across the LED array is please.
Can you also measure (this is important) what the signal at the base pin of the transistor is (magnitude and frequency if any).
This could be mains hum being picked up and amplified through grounding errors so that is worth checking.
The other possibility is that one of the op-amps is oscillating so also check on the output of each op-amp.
Welcome to the wonderful world of electronics! At least you will have learnt how much there is to learn at the end of it.
Andrew Davie wrote:
After my last post, I disconnected all wires, examined all joints carefully, noticed a couple that appeared to be less than desirable, and re-did those ones. Then I reconnected everything, and proceeded to do the measurements. Things have changed, and the LEDs are (mostly) off -- though I don't really know that this is a good thing.
Andrew Davie wrote:I did try NOT connecting the power to the NBTV boards, so the LED matrix was going through the NBTV boards' ground -- and lighting up. But I didn't do the waveform on this as it was before your question. NOw I can't get the LED to light up at all.
Andrew Davie wrote:
Looking at the input signal, this still looks OK at the pot -- it increases as I rotate the knob. It is recognisable NBTV type waveforms.
But what is very very strange is when I look at this signal as it gets to the LED driver board. Where the "video 1.4V in" wire comes from the sync board, I connected the red lead of the oscilloscope. I connected the black to a nearby "ground" pin on the same board. And the video signal has "shifted" by +6V. That is, I see a NBTV signal, but it's way "up" on my screen. I don't know what is happening here.
Andrew Davie wrote:When I measured same pins with multimeter, I get 6V too, so I know it's nothing to do with the oscilloscope settings. Very strange.
Andrew Davie wrote:I am wondering why all of the grounds on the circuit diagram are marked as "ground", except for one which is marked "power ground". I have assumed there is no difference.
Andrew Davie wrote:I've not yet got around to measuring voltage at the transistor, because my LEDs are no longer operational and I have a 6V offset of my video signal.
Andrew Davie wrote:I'm almost tempted to order a new set of NBTV boards and start completely from scratch. Frustrating.
Andrew Davie wrote:One new spanner in the works is an oddity I'm seeing on the oscilloscope signal when i have nothing at all connected -- just plain oscilloscope leads unconnected. I see a very small sine wave -- about 0.1V @ 20ms (=50Hz, our power frequency). If I ground the leads across me, the signal jumps to about 10x size. I'm a living amplifier.
gary wrote:I assume when you talk about the 'pot' means you are referring to the sync separator board (contrast)? That appears to be correct as there is a 6V bias on the op-amp. because the input to the LED driver board is AC coupled this DC offset is removed before it reaches the second op-amp of the LED driver board.
gary wrote:Here are the important places to take a measurement:
Pin 3 of the 2nd CA3140 op-amp on the LED driver board.
Pin 6 of the 2nd CA3140 op-amp on the LED driver board (or the base pin of the transistor).
If there is not a reasonable signal at these locations we can then start to work backwards.
