gary wrote:The voltage across the transistor from collector to emitter (Vce) will vary between your supply voltage (when the input voltage to the base is 0) to about 0.2 when the input voltage is at it's max (actually this is only if it is designed to be fully on i.e. saturated at this level but since we want white (max input voltage) to be LEDs fully on this is a reasonable assumption).
The voltage at the emitter of the transistor will vary between 0 and 2V because at the base it varies between 0 and 2.7 and there is (about) .7 volts dropped across the base to emitter junction. This means there is a maximum voltage across the emitter (gamma) resistance of 2 volts.
After a bit of a break, I've returned to this, and wired up the boards and rectifiers all together again. Like before, the LED array lights up with no input signal. This time I measured the voltage across the leads of the transistor, and I got the following
from base to emitter, 0.53V
from base to collector, 0.48V
from collector to emitter, 0.26V
I don't know what this means, really. One would assume that there is only 0.5V or thereabouts running through my LED matrix. Obviously not, though -- because all the LEDs are on. In fact, I can measure the voltage... hang on
OK, so the LED array is connected to my stable, rectified 12V supply which actually puts out 11.8V DC. If I measure across the LED matrix, I get 6.94V. What is this really telling me... that my LED matrix is using (11.8 - 6.94)V = 4.86V. Divide by 3 that gives each LED using 1.62V which I consider unlikely, but then again the LEDs aren't shining full intensity.
SO, where to from here? Why are my LEDs lighting at all. With no input signal, I would expect the voltage from base to collector of the transistor to be... well, 0.
-- One thing that just occurred to me -- I have NOT recalculated/replaced the resistors in the gamma circuit -- I am still using the originals. I must do that next, as a matter of priority -- that is, replace the three with a single one. A bit of a bummer, as they're soldered in. --
