Steve Anderson wrote:If this is the case the MOSFET is dead.
OK, after reading your advice I took the simplest route and just assumed the MOSFET was dead. Just to be sure, I bought two more of them and when I plugged the new one in, voila! the circuit works! So, now I know that dead components can cause hair loss. As you said
There's a problem, though -- at full power, the motor is now not spinning fast enough. The 11.8V that my rectified supply was putting out was barely enough to run the motor fast enough -- and now that we're losing some voltage through the speed circuit, it's not enough.
I considered the options...
1) fiddling with the resistors in the circuit -- tried, and nothing really seemed to make much difference.
2) changing the diameter of the wheel on the end of the motor to a larger one -- tricky, because I don't have an easy replacement.
3) using a different power source.
So, keeping in mind the interference that will come from using the same power supply as is powering the NBTV circuits... I hooked up to that anyway, just to see. And it all works. Very well.
I can rotate the pot and control the image quite well -- never getting it completely stopped, but it rolls at a very slow rate -- perhaps 1 frame every 10 seconds or so, when I have it adjusted nicely. So, the bottom line is that this speed control part of the circuit is working.
I've been getting excellent pictures using this setup. I tend to judge the picture quality by what I can see in certain clips from the club CD (#1). Those are clip #44, Karen, where I see if I can see the face of the guy behind her right shoulder (on our left) just before the words THIS IS KAREN appears. If I can make out a face, which I can, I consider the picture to be quite good. Secondly, I use track #46 which has the teddy bear. If I can see teddy's fur texture, and a pattern on his bowtie (just), then I also consider it's a goood picture.
Now, using the single power supply (19V or so)... I get very good pictures, and excellent speed on my motor. I suspect that I'm not seeing problems with the circuit/interference because the 19V feeds firstly into the 12V rectifier on the NBTV board... and that's filtering out any signal problems...?
As to the availability of components at Jaycar -- they do not carry all that they list. You have to order some of them in -- doesn't take long, apparently, but when I'm there I typically want to walk out with something, not order something and come back.
The images attached here are pretty much for record/historical reasons, just so I can come back to this someday and remember what it looked like
These images are all taken with the newly working manual speed control circuit, so image quality is indicative of what I'm seeing with the shared power source. They are all unenhanced, fairly indicative of the images I see with the eye.
