Klaas Robers wrote:Andrew, I made a new circuitdiagram for you.
Many thanks for the effort involved in this redesign, Klaas. I bought the components today, and wired it all up. The results are very interesting.
Firstly, the 10K pot now spins the motor faster and slower. I could not, however, get anything reasonable to a good speed lock -- it was either too fast, or too slow.... adjusting even a tinyest bit sent it into wild gyrations in the other direction.
After a while I started to think about why this was happening. Firstly, I suspected the 10K pot. It does seem to have a position which is discontinuous -- right at the point where the motor would be spinning at exactly the right speed.
But then I had a look at the rubber belt driving the disk from the motor. And it was in bad shape. Rips and tears on most of its surface, and this is entirely due, I am very sure, to the figure-eight loop that it is running to spin the disk in the correct direction. In fact, I think although this method is very clever, it is really NOT the right thing to do. The added friction (which was variable, because the surface of the band was all ripped/uneven) made it next to impossible for the disk to be spun at a constant speed.
So, I removed that belt and replaced with a rubber band -- with no figure-eight loop. Now my images are upside down -- that is OK for now; I will rotate the motor 180 degrees to fix that up later.
After finding that problem, I now find that it is much easier to control the speed of the motor. I can get it so that it is very very slowly 'rolling' the image. That is to say, I still can't get it stationary... but I can get it to the point where it rolls (say) one frame every 20 seconds.
The LED is installed as you have instructed, and it does indeed "go out" but only for a very short time, when the roll happens to be in the right place. We're talking half a second-short. Otherwise it appears to be flickering at high frequency, reasonably brightly. There's a definite 'dark/off' moment, though, as I mentioned.
Since I could not stabilise the picture manually, I had to chance following the rest of the instructions to see what happened. And, in short, nothing happened. There was no real effect, though once in a while I do think I saw a 'kick' in the image where it appeared to rapidly skip ahead a frame... but that could just be my imagination.
I could not find a 220K variable resistor with multiple turns, so instead I placed a 100K resistor in series with a 100K variable resistor. I think this will have been OK? There appears to be little effect when all is connected and I rotate the screw on this. I'm curious about the replacement of the two 100K resistors with the single 220K, because the wiring for the original circuit had the 100nF capacitor going to their connection. I assume the new 220nF capacitor is equivalent when connected as shown.
At this point I'm wondering if my motor is just so inaccurately controlled (that is, it responds so dramatically to voltage changes either because of the motor, or the rubber band pulley arrangement, or even because the end-bit on the motor around which the band wraps is off-center) that this is the reason that the sync circuit just doesn't get a chance.
One other thing, there was not enough voltage when driving the motor with 12V -- the motor would not run fast enough. I powered the motor instead from the 20V supply that is also driving the LEDs. This does not have ripple removed. The motor now spins fast enough (and as an interesting side-effect, the voltage regulator on my 12V power supply no longer gets super-hot). I'd be very happy to continue with this current power configuration -- a separate 12V circuit powering the motor driver circuit, and the 20V that powers the LEDs also powering the motor itself.
So, that's where things are at now. Obviously a lot better because I'm able to control the motor speed with the correct pot -- and to some degree able to get a steady picture. BUt still, no signs of synchronisation.
I did check the synch pulse and the IR pulse early on (but this was when I had two 22K resistors in series with the 47K (well, 50K) pot. At that point, I was essentially seeing 12V on each. After I removed the resistors so that I was compliant with the circuit diagram, I now only see 3.8V as teh IR receiver signal. I understand this is not good enough, but even so -- I don't get synch when they are there.
Klaas Robers wrote:Once the 220k pot has been set correctly only steps 1 to 5 are needed to get obtain synchronisation.
Are you saying that I will need to do steps 1 to 5 every time I turn on the monitor? I thought this was a circuit that would do the synchrnoisation automatically... once it was working, it was just a matter of turning on the monitor, and the picture would synch...?
