Steve Anderson wrote:Well, the trickiest part of this was/is the sync separator. Klaas did that work some years ago such that I didn't have to. Why re-invent the wheel? So Thank You Klaas.
Yes indeed thanks to Klaas's sync separator !,for me it was a bit tricky till i replaced the the CA3140 with a NE5534 then it worked fine with circuits components unchanged ,perhaps my CA3140 are just cheap copies of a better one that Klass was using ...who knows whats inside these things if some one can get away with cutting costs they will.
I found changing all the other CA3140's in the other circuits made no difference really just IC603.
The rest are slightly 'massaged' existing designs.
Well good to get circuits that work from proven designs !
The guy with the hard job was Harry. Getting the parts, laying out the boards, wiring it all up, getting various bits to work when they refused. And (we hope this continues) he's still with us after dealing with some fairly dangerous voltages. Even making his own high-voltage test probe, easy, maybe, but how many actually get around to doing it?
Lethargy, I can't be bothered with it.
Yes i don't want a shock from this monitor as i know if i did it might be the end of me Sobering thought ....every time i power it up i know what to touch and what not to...The high voltage probe is some thing i needed very useful i wanted this so i needed that to make that ..i knew all those 10meg resistors would come in handy one day 30 years later !
