Klaas Robers wrote:Oei Harry, I never work in that way. I always build stage by stage and first checking the just built stage. Then I always have a working circuit, or the fault is in the last built stage. Even when I rebuilt the old working monitor on a wooden frame onto the aluminium frame of the Heathkit SB500, I assembled and tested it small PCB by small PCB.
OH i agree Klass thats the way to go for sure ,i made my first SSTV monitor that way .
It is extremely difficult to find faults in the large circuits that you have built. At least for me..... Good luck. You'll need it.
I have PMed the the circuit to you to have a look at ,only reason i made it this way was it was from CQ magazine i would think it would of been checked before being published ,even so i expect it will need looking at here and there with changes which is always the way ,not all parts are 100% the same ...mistakes odd bad soldering connections;
i will take your good luck for sure
For the 5 kV, I think that you can use the small module. However, you should make a voltage stabilization for it. That is the input voltage should be dependent of the output voltage.
Oh so it really needs feed back to be stable its a lot of voltage to drop
Do you have the ability to measure high voltages to say 10 kV?
Yes i made a HV probe for when Steve was helping me with power supply the 3BP1 yes it will do 10 kv fine .
[/quote]The first thing then is to connect the module to a variable input voltage and measure the output voltage. Find the input voltage that gives you 5 kV of output voltage. For my self built fly back inverter with voltage multiplication this was about 14 volt. Two very high ohmic and long resistors in series bring this high voltage to an opamp circuit that regulate the input voltage of the inverter circuit by feed back. This circuit is fed from a voltage of about 24 volt. Then the 5 kV becomes a stable 5 kV, which is what you need.
Well this is some thing i have never tried and the module does only run up to 3 volts ,very high ohmic resistors might be a problem to find ,i might have to do what i can with what i have got ...if the feed back resistance can be over come and get the voltage down to some thing perhaps also a 4046 as a vco could be used ..might have to be low tech for the start i will have a think about it.
