Klaas Robers wrote:Harry, Steve, I can make a pdf of the word file in which the circuit diagrams are. However it is very old electronics. For the sawtooth oscillators I used a unijunction transistor. I fear that these are nowadays no more available.
But in which way can I transfer the pdf best to you? Include it in a post?
The resistances of the coils look promising. Higher than mine. And because you have + and - 12 volt while I have just + and - 6 volt, that will fit I think.
The magnetic deflection has the advantage that you may put the cathode and the grid of the picture tube at a reasonable positive voltage, somewhere between 0 and 100 volt. No need for isolation towards the grid or cathode video modulation. That is a big advantage of magnetic deflection. Only + 5 to 7 kV as an accellerator voltage.
hm.... let me try to include the pdf...... Captions and titles in Dutch. Not too difficult to decypher.
[/quote]You will see the size of my PCB's. And yes, I had the advantage of access to the Philips potcores, so I could make inductances at will. I like passive filters.
Steve Anderson wrote:...I am very aware of the bad memory problem...I probably forgot you had built up some of the circuits for this.
If what you've got already is working as it should I would leave it, no point in re-working it all. If you spot errors or something refuses to cooperate let us know...
Steve Anderson wrote:Going back to that filter, once the errors are corrected it works as advertised. It does centre on 1200Hz and its bandwidth is about 120Hz with a gain of 1.0.
The problem of the 50 Ohm pot could be fixed by raising its value and adjusting all the other values in that stage to suit, but if you've built it already, leave it be...apart from correcting the errors.
Steve Anderson wrote:Oh well, sadly there's no chance of that modified filter doing anything much. So when you can change it to yesterday's sketch and see if you get nice fat bursts if 1.2kHz coming out of it. The sync frequency in my posted SSTV wave files is quite close to 1200Hz so it should pick them out easily. It will need tuning via the pots first using those files...
Harry Dalek wrote:I had a go at tackling Steve's reworked sync filter..
Steve Anderson wrote:Harry Dalek wrote:I had a go at tackling Steve's reworked sync filter..
Well it's not really re-worked, just re-drawn as it should have been, I claim no originality for it. I'm sure the original worked as it should have, it was simply the sloppy translation from fag-packet sketch to printed article that caused you headaches.
The filter values can be adjusted widely to achieve the same result. I had a look around a few days ago and it seems the lowest value front-panel pot that is easy to get is 1k, 20x the original 50 Ohm version. But if you raised all the other resistors in this filter by the same factor and reduced the capacitor values by the same amount you'll end up with the same result.
BUT, the 82k resistor becomes 1.6M and you could not use a 741, something like a TL071 as a minimum would be required.
In fact, for the heck of it I recalculated the values which are a bit different to exactly x20 but end up being a better filter. I simulated it with a TL071 and the curves are below. The red trace is the frequency pot in the centre, the other two are with the pot at either end.
Because some of the values are now quite high you'd need to be careful with hum pick-up.
