Klaas Robers wrote:Congratulations Harry, it looks as if you have successful finished a very delicate process. Write down the voltage on the LED-resistor combination that you applied for a decent increase of PMT output current. Then later, after you switched the PMT voltage off, you may open the enclosure and experience the light output of the blue LED at this setting. I bet that you have to make the room dark before you can see the tiny blue light output. PMTs are very sensitive. This is needed behind a Nipkov disc that has a "transparency" of less than 0.1%. Tis transparency number is normal for a 32 line disc.
Good luck with your further experiments. This is science.......
Klaas Robers wrote:Wow, if even with a 100k in series the applied voltage is no more than 2 volts, I would try a 1M in series. You can place that resistor directly from the low voltage power supply to one of the wires going to the LED inside the dark box. You even can place a second identical LED in series in this chain. Outside the box of course. Both LEDs will do the same, so you can see the effect of the current on the LED.
I would only be satisfied if the voltage that you apply to the series chain can be increased to about 5 to 10 volts with a reasonable response of the PMT tube. Then you know that the resistor is mainly responsible for the current and not the very non linear "resistance" of the LED diode(s).
Good luck, Klaas
TaraByers wrote:The yellow output of white LEDs is generated from the UV excitation of a phosphor which can be quite slow in response time. Though the PMT shouldn't much respond to it, why throw another potential variable into the equation? White LEDs are marginal even for NBTV, they may get better with time but generally white LEDs are used in flashlights and other simple devices where human eyesight is involved - and that's not particularly fast.
Klaas Robers wrote:Harry, you have not placed a high ohmic resistor in series with the LED. 1k is not high ohmic. What you are seeing is the non linear characteristic of the LED diodes, because you are driving the LEDs by a voltage, not by a current.
...When you drive the LED by a current, then the output staircase will be just like the input staircase. However most NBTV LED-driver circuits have gamma-correction, which is non linear itself. For these experiments you want to have a linear circuit, so don't use a standard NBTV LED-driver.
