Harry Dalek wrote:I tried a few setting changes on the preamp and the pot into the video sync mixer they both gave a level change one in gain other in brightness looking at other NBTV wav videos on Garys scope as i mentioned in the last post i am next looking into the sync level ,it looks to me on black level mine is still way to large which i think the effect on the camera is a limit on the gray scale ...more than likely only getting half /
gary wrote:Looking good Harry, I have looked at one of the 2 signals you sent me and I can see that if you could get your disk speed more consistent you should be getting some darn good pictures. The speed doesn't have to be exact but it should be as consistent as possible over at least a frame period - at the moment it fluctuates considerably over just a line period which distorts the line length considerably. I think that even if you increased the mass of the disk with a circular weight of some kind to get more of a flywheel effect I would expect a big improvement. On the other hand improving your speed control mechanism would be even better.
Harry Dalek wrote:
Hi Gary
I'm Still using one of the original nipkow's i was testing on the first flying spot camera so it has the cut out encoder stuck on the disk ...as i recall no matter how good i am at cutting it would never be as good as a direct encoder print out ..now the pulse widths must be a touch out each line ....Remember all the problems i had with the reflective opto switch ...i now can use a print out i have not bothered up to now as i was not sure the thing would work so just used what i already had .
This might help as well so will look into that .
Will have a think about what i can use as a fly wheel a am sure i have something in my shed .
I am using the 4046 pll over the 555 bistabe i just have both wired up ,one works depending on if i have plugged its ic in and pulled the other out ,i did a lot of just in case with this see what was better .
Well i will work on your advice...here's a short test i tried of me if i kept in the focus area might of been better
gary wrote:
Oh Harry, my apologies, yes I see by closer inspection that the line variation is constant across frames so yes it is your encoder at fault not the speed of the disk (although that is varying somewhat too but nowhere near as badly as I thought).
Well that's different - when you put a new encoder on that problem should be solved - I can't wait to see it, it should make a BIG difference.
Hi Gary
I will look into printing an encoder out ,i should have time to mount and test tomorrow ...
Yes it could could well be that we will find out for sure tomorrow,if there is still a problem .
Ii i need more mass on the disk i was thinking of using large steel washer i would think a fly wheel effect would work better on the edge of a disk than closer to the center but might be enough for that little cd motor any case i will see how the encoder improves it .
I have up loaded another me try today with the cleaner Nipkow holes apart from one trouble maker may be i have one over lapping ...any way what i did was waving my glasses about like a fool ( have to be careful not to brake them or my NBTV days are over till i get a replacement !) and again i see the focus was much closer to the lens than i was expecting BTW you may notice i have my gardening hat on .....Increasing the light levels just into the room with the blinds up you get the effect of that wavy black bar above my head when you decrease the light levels that tends to go flat ...you also get the bright white spots from any thing reflecting back to the lens that is to white ...so its either a better picture with lower light levels that look washed out or like this with more light ...
Not sure this is an encoder problem...see what happens tomorrow.
gary wrote:
Hi Harry, on further reflection I think I have to go back to my initial analysis - your disk "appears" to be hunting. Have a look at the following snapshot:
Looking at the sync bar (which is quite narrow BTW), the bar is wavy and quite jagged - I think the waviness is due to your disk "hunting" - that is speeding up and then slowing down, and the jaggedness of the line is due to minor variations in the encoder.
When I step through the wave file the sync bar waves up and down sinusoidally - a tell tale sign that your disk speed is hunting around the required speed for some reason.
So maybe a flywheel would help - personally I think you would be better off with one of the voltage regulator type speed controls as the speed will still vary but much more slowly - that is common type of speed control for cameras so it can't be too bad. Just a thought though.
actually have some software that can use the sync zero crossing position to correct that waviness - if I can find it I will see how well it works on your signal.
PS: A flywheel must be well balanced, adding a washer to the outside of the disk will ensure chaos - unless you add other washers to balance it up - a real pain in the proverbial to do.
Old cassette, tape, and VCR players are full of flywheels - I bet you have hundreds of them.
I think I saw a tacho encoder on the inside of your sync encoder - have you tried using that to check your disk speed (using a 50hz light source)?
